Picture of Your Boat on the Hard - Page 14 - SailNet Community
post #131 of 156 Old 12-31-2008
Whampoa's Avatar
Initially we loaded her bow forward but the weight distribution didn't suit the trucker so we reloaded her stern forward.
I had prepped the boat not knowing how she would be loaded but having seen it done both ways. Everything was off the deck, all hatches were fully secured and all vents were sealed. The only change I had to make was to remove the bow pulpit as a precaution as it was at 13' and the limit was 13' 6'. We felt that was too close for comfort. It took another 30 minutes to remove and stow the pulpit.
She came across the country from La Conner WA to Oriental NC in 6 days and without a mark or opened seam.
Regards, John
Whampoa
US East Coast
1962 40' Auxiliary Cutter
S.S. Crocker - Design # 330
Whampoa is offline
post #132 of 156 Old 01-02-2009
donhaller's Avatar
Here's mine. This is my first sailboat. She is a '73 C&C 25 Mk1.
I just had her pulled two weeks ago to do some work before spring. If I get some nice days I plan to clean the hull and deck and start doing little things that need attention. I dropped the sails off that came with the boat to have them checked out and to help me identify what I actually have. I got five bags of sails with the boat but I'm not sure what is there and their condition except the main sail that I I just removed.
Here's a link to shots of the boat when I first went to look at her back in November.
Good Ship Lolipop photo - Don Haller photos at pbase.com
Chesapeake Beach, MD
C&C 25 MKI, Hull No. 039
donhaller is offline
post #133 of 156 Old 01-02-2009
Don—
Just a warning—if she's not on concrete when you put her up on the hard, you probably should have the blocks supporting the keel on a very thick plywood plate, and the boat stands on plywood as well. I've seen some pretty ugly things happen when the ground got saturated and the stands started to sink into it... dominoes with sailboats... not good.
sailingdog is offline
post #134 of 156 Old 01-02-2009
large boat needs a large crane
plimsoll is offline
post #135 of 156 Old 01-02-2009
donhaller's Avatar
Don—
'dog,
I'll see if I can get that addressed soon. It's hard to see in the photo, but they did manage to stick a small block of wood under the keel to give some support and there are some scaps of ply under the stands. I was planning on going down there today anyway if the weather cooperates and I'll see if they do that for me.
Thanks for the good suggestion
Don
post #136 of 156 Old 01-02-2009
CaptainForce's Avatar
This view shows the appearance of our hull after 3 years and 8 months since the last bottom paint.
Our only home has been a 1973 Morgan OI since november of 1973.
Ready to launch and back to seasonal latitude cruising.
'take care and joy, Aythya crew
CaptainForce is offline
post #137 of 156 Old 01-02-2009
Great thread.
Here is our boat. 1971 Seafarer 31 Yawl. Lots to do, but at least no blisters!
Danjcon is offline
post #138 of 156 Old 01-02-2009
If the ground gets and stays wet for a while...little scraps aren't going to cut it... The biggest problem will be getting the support under the keel blocks...putting them under the boat stands is relatively straightforward and you could do it yourself... putting them under the keel blocks requires lifting the boat... not a DIY type project.
'dog,
Don
post #139 of 156 Old 01-02-2009
Dan—
Highly recommend getting some plywood bases for your boatstands and the keel blocks... DAMHIK
Originally Posted by Danjcon View Post
Great thread.
post #140 of 156 Old 01-02-2009
Ticon 30
dbruce85's Avatar
This was taken in spring 07 a few weeks after we bought her. Just before the mast was stepped
dbruce85 is offline
What's your biggest bonehead move sailing? CharlieCobra Seamanship & Navigation 613 07-19-2016 08:10 PM
The Search for the First Boat - long learning curves pmoyer Boat Review and Purchase Forum 45 12-20-2008 01:28 AM
Trailering? Pick a Boat Bruce Caldwell Cruising Articles 0 07-22-2004 08:00 PM
The Balance of Hull and Sails Steve Colgate Learning to Sail Articles 0 05-25-2000 08:00 PM
The Balance of Hull and Sails Steve Colgate Buying a Boat Articles 0 05-25-2000 08:00 PM
