Heaving to at high speed.."the hand brake of the seas"...video - Page 2 - SailNet Community
post #11 of 40 Old 12-07-2008
Seattle Sailor
Very nice video. Thanks for the demonstration of a quick-stop heaving-to.
I, for one, appreciate the effort and time you take to make these videos. It is very valuable for a relatively inexperienced sailor like myself to see examples of how others do even some of the basic maneuvers. I can't wait to get out and try this technique to see how far way from a MOB I end up (unfortunately, for those of us on the Great Lakes, it will be at least 4-5 months)
Keep the videos coming, and thanks again.
PDean
CS 34
Seattle, WA
"The pessimist complains about the wind; the optimist expects it to change; the realist adjusts the sails." - William Arthur Ward
padean is offline
post #12 of 40 Old 12-08-2008
Harvester's Avatar
Originally Posted by paulk View Post
We fly a symetrical chute, with a pole. The procedure is to tack, all standing, and sort out the mess afterwards. That is what we did. It works equally well. We had no damage to the 3/4oz spinnaker.
Wait a minute! You heave to with the symetrical spinnaker poled up? And you say the procedure is the same as with the jib? Wow! I'm looking forward to a sailing day with some 5 or 6 kt wind to try it...
Harvester is offline
post #13 of 40 Old 12-08-2008
Thanks Courtney.
Real gentlemen never sail to windward...
That describes most of sailing...
So what is your excuse??
hunter Legend 37 Semper Paratus
Formerly - Tartan 34C Yawl
T34C is offline
post #14 of 40 Old 12-08-2008
Hesper's Avatar
I'd love to see the video, but when I CLICK HERE NOW I get some wierd Portuguese werewolf site. What gives?
Hesper is offline
post #15 of 40 Old 12-08-2008
Hesper-
Click on this video:
sailingdog is offline
post #16 of 40 Old 12-08-2008
jackdale's Avatar
There is a technique for heaving-to in MOB.
1) Heave-to as soon as MOB is noted.
2) Beam reach a little until MOB is abeam of helm
3) WITH SAILS SHEETED IN, sail downwind until MOB is off the quarter
4) Head up onto a close haul / close reach until MOB is off the quarter
5) Heave-to again, use a shroud as a guide to drift down to MOB.
Different boats respond differently; e.g., self-tacking jibs may not heave-to. Practice is the key.
One person can do this and be able to snag the MOB on the leeward side. In addition, you never lose sight of the MOB.
If you are doing a MOB from a beam reach or broad reach, sail back so you can heave-to.
One criticism is that the boat will drift into the MOB causing an injury. In my experience the water being pushed by the boat going to leeward will keep the MOB away from the hull.
Try it - you might like it.
Jack
jackdale is offline
post #17 of 40 Old 12-08-2008
Montgomery 17
Perithead's Avatar
Nice Giu.
The boat looks great too!
Small is beautiful, simple, cheap, and easy......
Sailing Videos, Woodworking Videos and More!
Perithead is offline
post #18 of 40 Old 12-08-2008
paulk's Avatar
Giu's use of the term "heaving to" is perhaps not apt in a MOB scenario. What we did with the spinnaker up is called a "Quickstop" maneuver. The main idea with a Quickstop is to keep the boat close to the MOB, slow it down, and get the boat back to the victim as soon as possible. The main idea with heaving to is to put the boat on a better angle and speed to the wind and waves so as to put up with bad weather over a long time. I would not want to "heave to" with a spinnaker up, but would be happy to tack with one up (as we did, several times) if it meant picking up a victim sooner.
paulk is offline
post #19 of 40 Old 12-08-2008
paulk's Avatar
There are lots of ways to skin cats
Jack
One reason the "Quickstop" was developed was because people who go off on a reach until the MOB is abeam, then sail downwind with the sails pulled in, then go to close-hauled, and then heave-to are so busy checking through the steps and the procedures that they lose sight of the MOB. If the directive is simply to tack - no matter what- it keeps you closer to the victim and slows you down. Both these things help make recovery of the victim quicker and more certain. Someone trying to do a quickstop may end up going through the reaching/downwind/upwind/heave-to scenario, but doesn't have to. While the reach/return system may work, keeping it simple may work better.
paulk is offline
post #20 of 40 Old 12-09-2008
jackdale's Avatar
I have done the heave-to method with hundreds of students over the past 12years. The issue you raise has never been a problem.
Heaving-to really slows the boat down and the MOB is always on the same side of the boat and close in, hence we never lose sight. When you have to tack, the MOB will disappear behind the bow and foresail. In addition, tacking while single handed after an MOB is no easy task. The heave-to method simply involves sailing around the MOB.
Jack
jackdale is offline
Windward performance deseely General Discussion (sailing related) 21 04-01-2012 02:42 PM
Atomic 4 is 4 lovers agent4change Gear & Maintenance 11 08-07-2011 05:14 PM
Basic Thoughts on Tides Jim Sexton Learning to Sail Articles 0 11-17-2003 07:00 PM
Basic Thoughts on Tides Jim Sexton Seamanship Articles 0 11-17-2003 07:00 PM
Hull Speed Demystified Steve Colgate Learning to Sail Articles 0 06-10-2000 08:00 PM
