Heaving to at high speed.."the hand brake of the seas"...video - Page 3 - SailNet Community
post #21 of 40 Old 12-09-2008 Thread Starter
Originally Posted by Hesper View Post
I'd love to see the video, but when I CLICK HERE NOW I get some wierd Portuguese werewolf site. What gives?
eheheheheh
keep clicking on that werewolf link....I appreciate it
Fred is wining and I need all the help I can get
Giulietta is offline
post #22 of 40 Old 12-12-2008 Thread Starter
in a MOB situation, (in cold waters), I am sorry to tell you, but my first priority is to start the engine,
my steps are
heave to to stop the boat and maintain eye on MOB
start the engine
roll genoa while steering to MOB
depending on seas and wind, main stays on or comes down..and if it stays its either sheeted in or fully lose..depends on conditions..
on my boat, to start the engine, roll the genoa, lower main and motor with engine to recover..all takes me about 30 seconds or less, so in a life death situation..I'd gett all sails off and motor..
post #23 of 40 Old 01-27-2010
tager's Avatar
Chop chop chop chop.
*Water turns red*
tager is offline
post #24 of 40 Old 01-27-2010
*Water turns red*
You must have skipped over the part where he said." maintain eye on MOB"
knothead is offline
post #25 of 40 Old 01-27-2010
It's interesting - after reading through those 100+ Lifesling case studies that JRP put up, starting the engine seems to be a bad idea in most cases if you can get back to the COB by sail.
In any case, it seems like it's pretty critical to do a check for any lines in the water prior to starting the engine and should be part of the procedure list.
Have you guys seen those freakin' case studies?
smackdaddy is offline
post #26 of 40 Old 01-28-2010
Originally Posted by Harvester View Post
Wait a minute! You heave to with the symetrical spinnaker poled up? And you say the procedure is the same as with the jib? Wow! I'm looking forward to a sailing day with some 5 or 6 kt wind to try it...
Honestly, in downwind conditions when you're most likely have someone go swimming, it isn't going to be blowing 4-5 kts. If it's light, almost anything will work, but at 20kts+ true (this is when a good hard round up or down is going to drop someone over the side) I'm pretty sure you'd loose your kite, possible bend or break the pole, and end up with an unholy mess that could really jeopardize the rig well before you got back the the MOB.
puddinlegs is offline
post #27 of 40 Old 01-28-2010
St Anna's Avatar
I saw the result of a cat doing this. His mast step cracked and the mast jumped 2' across the deck - very close to going throug. He let go the traveller and main sheet, rounded up and saved the mast.
He was sitting awaiting a new welded mast step, sitting in paradise, enjoying the serenety. We moved on. I sometimes wonder how he got on.
St Anna is offline
post #28 of 40 Old 01-29-2010
Omatako's Avatar
Sorry, how do you figure that? If your boat has rounded up anyway, that's a great time to douse sails and get back to th MOB. If your boat rounds up and that threatens to bring your rig down then you're WAAAAY over-canvassed.
There used to be (and God forbid, maybe still is)an international practise of sailing off on a reach and counting the seconds while the boat is being prepared to turn around and then when everyone is nice and comfy, sailing back to the MOB, hoping to hell that your reciprocal course is accurate and that you don't have to put in a tack and then miraculously you'll find the MOB where you thought he'd be.
If that is the process that is being used on a boat then the helmsman/skipper needs to include the description in his safety briefing. I for one will get off the boat right there.
I often disagreed with Giulietta but on this he's bang-on. I fully endorse the process of rounding my boat up if there is a person in the water. I go directly head to wind, drop the main, furl the headsail, start the engine and get back to the MOB ASAP.
If the helmsman thinks there is a risk of running over the MOB to a point where he's going to put him amongst propeller blades then MOB practise should begin with driving lessons, not sail management.
Arthur C. Clarke
Omatako is offline
post #29 of 40 Old 01-29-2010
tdw
Super Fuzzy Moderator
tdw's Avatar
Well put Andre.
You'd have to figure that hitting the poor bugger with 10tonnes or so of yacht has probably done for him before the prop even gets a share of the action.
Andrew B (Mal 39 Classic)
Life is a trick, and you get one chance to learn it.
― Terry Pratchett.
tdw is offline
post #30 of 40 Old 01-29-2010
St Anna's Avatar
ditto above.
UNless he has dived off the bow, turn on to him - turn way and 1. you could mince him, 2. you will lose windage and have to fight to get it back.
The theory has to let the yacht be to weather of the victim. owever,if the poor sucker is to weather of you, he should drift onto you and you can collect him and drag about the stern to the lee side. All in theory - I've only collected hats and milk bottles (MOB)in practice
I refer to the victims as 'him' as girls are too smart - check any stats - more fellows go over the side than females - they have a better sense of survival or males do the stupid/dangerous stuff!!
St Anna is offline
Windward performance deseely General Discussion (sailing related) 21 04-01-2012 03:42 PM
Atomic 4 is 4 lovers agent4change Gear & Maintenance 11 08-07-2011 06:14 PM
Basic Thoughts on Tides Jim Sexton Learning to Sail Articles 0 11-17-2003 08:00 PM
Basic Thoughts on Tides Jim Sexton Seamanship Articles 0 11-17-2003 08:00 PM
Hull Speed Demystified Steve Colgate Learning to Sail Articles 0 06-10-2000 09:00 PM
