  #31 (permalink)
Old 01-09-2009
NCC320 is on a distinguished road
Jiffylube,
Unfortunately, I believe your situation is probably a frequent situation. My wife will come sailing if I press the point, but she does not like sailing and will not try to learn....that's ok, I won't do somethings she does (yes, I know we should strive for things that we like to do together, and we do, but not on everything). She doesn't mind if I have boats and spend time on them. For a time, if she or other persons were not available, I just did not go sailing. And, it seemed that often when we planned sailing in advance so as to fit into other people's schedules, the weather often didn't cooperate on the appointed day...no wind, too much wind, too hot, too cold, stormy, etc., and when conditions were right, crew was not available. After a time, I decided that the solution for me was to be able to single hand the new boat (Catalina 320)...I did so on the older, smaller boat, but the new one was bigger, the prevailing wind is always a cross wind, the slip is narrow, and I really didn't (and still don't) want to ding the boat. In my case, I have put in a number of assists that ease the issue of dock/undocking singlehanded. Now, if someone (wife or others) can go on short notice, great, and if they can't, I still go. Granted, in single handing, I miss out some good sailing because I'm not going in higher wind conditions that would be great for sailing, but which would complicate the docking. Purists will turn up their noses at this, but assists help. Maybe similar things would help in your situation. I've put buddy lines between the pier and outside pilings. I back into the slip since that puts me in position at the helm to make fast lines to pilings as I enter the slip, I lock down the wheel brake partially so I can take my hands off the wheel to handle lines, I've rigged a bow line through a snatch block to the cockpit so I can tend it from there. I use a carabiner hook tied to the bow line (pre led outside the life lines back to stern) to hook on the bow line and a similarly carabiner equipped stern line for the stern cleat. When I come into the slip, as I pass the windward outer piling, I hook the bow line carabiner onto the windward buddy line first, then the stern line carabiner and cleat the stern line off tight. Now, the stern is secure, so boat continues to back into the slip as the stern carabiner slides down the buddy line, and I tend the bow line without leaving the helm. By backing into the slip, if I need to abort, the position with the most power to correct for an error is the going ahead orientation. I start my backing outside the fairway to allow all the competeing forces to work themselves out where there's plenty of room. Now, once I'm going down the fairway in reverse, the boat is fully in control, and I have only to calculate my turn correctly....looks funny, works great if cross wind or down wind isn't too great. If you don't want to use the carabiners and buddy line, then same idea works with putting a bow line and spring line on piling. If you are on a floating dock, perhaps a bracket at the end of the dock is appropriate to hold the lines within easy grasp as one approaches. For marginal docking conditions, I've installed a safety line at hull level from the outboard piling to the pier (on the lee side) that I tighten (before going out) when things look dicey...in those conditions, I have to come in bow first and this line will keep me from dropping down on finger pier or neighbor. For departure, I have a loop in the windward buddy line at the stern boat cleat to which a temporary stern line is attached, and a breast line secured by a line with a toggle between buddy line and boat's midship cleat. The toggle line and this stern line are handled from the cockpit at the instant that I'm ready to go. This temporary arrangement allows me all the time in the world to remove normal dock lines without being blown around in the slip. Training wheels....perhaps so, but they allow me to single hand without beating the daylights out of my boat and neighbor's boat. Each situation is different, but some similar arrangements probably can be arranged for each person's (and your) docking situation. Looks funny...ok. Now I can come and go with or without crew. If there is someone available to go sailing, great, and if not, I can still go. Just a suggestion to consider to get more sailing into one's life.
  #32 (permalink)
Old 01-10-2009
JiffyLube's Avatar
Grasshopper
JiffyLube is on a distinguished road
Originally Posted by timebandit View Post
Thanks for the thread...I'm taking my time reading it.
  #33 (permalink)
Old 01-10-2009
Jim H's Avatar
Jim H is on a distinguished road
Try all women classes.
I second this.
It's also worth having or borrowing a boat that's the right size for your wife to take out with her friends, without you. When we were members of a sailing club, my wife would do that with their Catalina 22s and have a great time.
Jim H
London, UK
Aurora, a mighty Cal 20 (Portland, OR)
Southern Rival, a seasoned Rival 34 (Gosport, UK)
  #34 (permalink)
Old 01-10-2009
seachest is on a distinguished road
Sounds like somethings never change. I bet they brag about that boat to there friends and show them a picture of how it looked when it was new. I've seen some nice boats go cheap. The marinas want to recoup back slip fee's and normally auction them off once the owner stops paying the slip fee"s. When i managed a marina we had a-f dock and debt row.
  #35 (permalink)
Old 08-16-2009
L124C's Avatar
L124C is on a distinguished road
4 years ago I found a really nice 30' boat for sale. I had it surveyed (it surveyed well) and made a reasonable offer based on the survey. The owner countered and I rejected the counter. I drove by his marina the other day, and the boat is still sitting there. Now, in terrible shape (really made me sad). He couldn't get 25% of what I offered for the boat now, and has spent over $8,000 in slip fees in the meantime. The funny thing is, apparently his kids sailed the boat for him. They have grown and moved, and thats why he was selling the boat. He couldn't sail it if he wanted to, he doesn't know how! He is in Real Estate, and you would think he would realize the concept of a depreciating asset becoming a liability. For some reason, with boats....logic often goes out the window! I wish someone could explain it to me.
  #36 (permalink)
Old 08-16-2009
sarafinadh's Avatar
sarafinadh is on a distinguished road
our marina has boats that haven't left the slip in 10 years... you can see from the registration tags on them.
I don't get it either. At one point one of the family boats was damaged in a storm and became an impossible project. Selling wasn't a possibility because of the extent of the damage and we had to pay to have her wrecked, which still makes me sad when I think about it...
I wonder if this is the case with some of these derelicts... beyond salvage and it costs a chunk upfront to wreck em so folks just let em sit year after year...
I walk by em and think how nice it would be if I could go on those old boats and strip em of all the nice stuff on em to make our little hole in the water even cooler!
sara
ain't what ya do, it's the way that ya do it...
  #37 (permalink)
Old 08-17-2009
L124C's Avatar
[QUOTE=sarafinadh;514184]our marina has boats that haven't left the slip in 10 years... you can see from the registration tags on them.
QUOTE]
What was the net cost of having the boat wrecked? I assume it had some salvage value? Just curious. Fortunately, I have never known anyone who had it done and have always wondered how it worked. Regarding the derelict boats. Most of those in my marina are salvageable. In a better economy, the owner could have simply let them be seized and go to auction. Instead, they kept paying slip fees and letting the boat deteriorate. Now, the number of seized boats has increased about three hundred percent, with many of the boats obviously having been cared for A Bay Area sailing magazine recently showed a picture of a string of 10 or 15 boats being towed from a marina to the wrecker. They all had no takers at auction. Come to think of it, its been a long time since my marina held an auction. With all this inventory, that seems strange. Maybe they know it's futile, and are giving the responsible boat owners a grace period, as their boats would probably be the only ones snapped up.
  #38 (permalink)
Old 08-17-2009
sarafinadh's Avatar
I don't know what it cost exactly... My folks arranged it. We had it done in the northbay area... maybe Marin. My recall is that it was around 3k but I could be very wrong. It had a new head/macerator/tank system on it that must have been worth something... and LOTS of mahogany... and a big ole chevy engine that ran like a top.
but I don't really know
sara
  #39 (permalink)
Old 08-18-2009
MrDoug is on a distinguished road
I picked up my boat by asking the yardmaster at a local dry-dock "who hasn't paid their bill?"
I ended up buying a FULLY loaded, and very nice Cape Dory 25 for under $2K.
It pays to ask...
Boats of Shame Hartley18 General Discussion (sailing related) 233 12-22-2010 01:00 PM
hit me once shame on you..hit me twice shame on me... Giulietta Off Topic 19 05-05-2008 08:16 PM
Lucky Giu Cruisingdad Off Topic 22 10-25-2007 03:22 PM
new windvane selfsteering on the market hancopoot Gear & Maintenance 15 03-28-2007 05:22 PM
Shame on you....shame on you.... afterguy General Discussion (sailing related) 36 11-30-2006 10:35 PM
