Anybody ever hear of a - SailNet Community
post #1 of 8 Old 09-17-2002 Thread Starter
Aibury -- Apparently it was built in the bahamas. It is a full keel 24''sloop mfg in 1981. Has a nice look to it with a bowspirt and gaff rigged. Wondering if anyone knows of this boat, Its performance, seaworthiness etc. ??
Please advise.
Thanks
Steve
DrakeSteve is offline
post #2 of 8 Old 09-17-2002
Moderator
Jeff_H's Avatar
I assume you mean Albury. The Alburys are a family of boat builders in the Abacos. They decend from English loyalists who left the newly formed U.S. after the revolutionary war. They are highly regarded as wooden boat builders building many a fine Bahamian Dinghy and Bahamian Sloop. I considered buying a wooden 28 foot Albury sloop back in the early 1970''s. The workmanship was quite good for an island built boat. The Bahamian sloops are generally robustly framed with double sawn framing (madierra or horseflesh) and fairly heavy Atlantic Longleaf pine planking. They generally use pole spars rather than hollow spars. Most of them that I have seen have been galvanized iron fastened. A lot of Bahamian sloops used internal ballast which can rot out the planking and cause damage to the Garboard strake. The galvanized fastenings have a limited lifespan of maybe 20 to 25 years and can promote rot in the frames. (Troughing which cannot be seen from the surface.) Also, in my experience the pole spars are a little prone to rotting at the maststep and partners.
Bahamian sloops derive from island work boats. They generally have very large sail plans and sail well in a wide range of conditions. They are not really intended to be offshore boats but they can handle quite a bit of breeze is sailed well. They use a shore gaff or an oversized headboard that looks almost like a Dutch rig.
While many of the Bahamian sloops are quite fast by traditional workboat standards, by modern standards they are not all that fast. Still that is not what these boats are about, Sailing wooden boats like these is about a different kind of experience, one that offers a very rich experience but very different that sailing more modern designs. Boats like these take a lot of skill to sail well and to maintain. Kept up with. they are very rewarding.
Jeff_H is offline
post #3 of 8 Old 09-18-2002
Good Lord, Jeff_H. Is there anything you don''t know?
tarmand is offline
post #4 of 8 Old 09-18-2002
What do you expect...He''s one hundred eighty three years old!
Dennis
windship is offline
post #5 of 8 Old 09-18-2002
Moderator
Jeff_H's Avatar
At 52 years old (40 plus of those spent sailing and reading about sailing) there is a lot that I have seen and learned, and still a lot more that I still have to learn. I still come to places like this to learn, as well as, to help pass on whatever info I can. When you stop learning you have stopped living I always say.
To be frank, I am not terribly knowledgeable about many of the newer electrical/ electronics systems or refrigeration systems and I am learning about bigger diesels.
Regards,
Jeff_H is offline
post #6 of 8 Old 09-19-2002
Jeff keep up the great work I enjoy reading your answers
colehankins is offline
post #7 of 8 Old 09-19-2002
I guess I should''ve put one of those smiley faces on my post because I meant it as a compliment.
tarmand is offline
post #8 of 8 Old 09-19-2002
Moderator
Jeff_H's Avatar
I knew that you did. I should have included a smiley face on mine. 8^)
Jeff_H is offline
In-mast furler; to buy or not to buy; GreggRuch Boat Review and Purchase Forum 55 04-25-2011 06:40 AM
It can happen bubb2 General Discussion (sailing related) 63 11-14-2009 10:29 AM
Powerboat Cruising info needed m000ve0ver Cruising & Liveaboard Forum 21 06-13-2004 05:24 PM
Hear the Latitudes and Attitudes theme song! SailingAway Cruising & Liveaboard Forum 0 03-17-2001 10:02 AM
