Old 01-16-2009
hertfordnc is on a distinguished road
20 degree engine start
Just thought I'd share this for the folks who will appreciate it.
20F is really cold for the locals here in NC.
I went to check on her at 0530 on the way to work. THe batteries are not as good as they could be but by disconnecting the compression on one cylinder and advancing the throttle a lot I was able to start the 30 year old Yanmar 2QM20 without glow plugs.
I figure that's the bottom end of what I will ever ask this engine to do.
In over my head?
First Boat, a well-equipped 1977 Camper Nicholson 31
What is all this stuff and how does it work?
Old 01-16-2009
erps's Avatar
the pointy end is the bow
How did you deactivate one cylinder?
Ray
S.V. Nikko
1983 Fraser 41
La Conner, WA
Old 01-16-2009
Boasun's Avatar
Boasun will become famous soon enough Boasun will become famous soon enough
A touch of ether helps diesels start also... But be careful in the usage of ether, because your engine will develop an ether starting habit if you use it all the time.
1600 Ton Master, 2nd Mate Unlimited Tonnage
Maritime Instructor
S/V Rapture
Old 01-16-2009
bubb2 has a spectacular aura about bubb2 has a spectacular aura about bubb2 has a spectacular aura about
Each cylinder on a Yanmar has it's own decompression lever.
Never Forgotten
Old 01-16-2009
cruisingdream is on a distinguished road
ether causes pre compression ingnition burning holes in pistons
never use ether
is you need a supplement use wd40
Old 01-16-2009
denby's Avatar
Location: Dead Sea, some times called Long Island Sound
denby is a jewel in the rough denby is a jewel in the rough denby is a jewel in the rough denby is a jewel in the rough
I have the 2QM20F and I'm always amazed how easy it starts.
Dennis
O'Day 302
Be careful or i will do what the voices tell me to do
To get the most from Sailnet, follow the link in
's signature.
Hey stuffit "Get a life"
Old 01-17-2009
Rockter will become famous soon enough
If your compression is good, and your oil has not thickened to treacle and emasculated your starter motor, the diesel really should start even when that cold. If compression is good, the temperatures at the top of the compression stroke are fierce, and the ambient temperature does not matter much.
Pls don't use narcotics to start the motor. It gets addicted to them very readily, then it's a diesel junkie.
Cruising without an Engine Mark Matthews Seamanship Articles 0 06-07-2004 08:00 PM
Surveying a Diesel Engine Tom Wood Buying a Boat Articles 0 01-26-2003 07:00 PM
Safety Check Mark Matthews Gear and Maintenance Articles 0 01-25-2000 07:00 PM
Engine Checkup Tom Wood Buying a Boat Articles 0 03-26-1999 07:00 PM
Engine Checkup Tom Wood Gear and Maintenance Articles 0 03-26-1999 07:00 PM
