Genoa sheets knots, tip for newbies - Page 4 - SailNet Community
post #31 of 41 Old 01-26-2009
AdamLein's Avatar
Can you guys clarify what you mean by "foiled" jibs?
My jibs are hanked on but I like the idea of using separate tracks for small and big jib -- I've never really made good use of the inner tracks. I think I might need a new fairlead car?
AdamLein is offline
post #32 of 41 Old 01-26-2009 Thread Starter
The foil is that track at the front of the sail, some tracks or foils have 2 slots so you can raise one sail with the other one still up..
Wait, I'll post a photo
Giulietta is offline
post #33 of 41 Old 01-26-2009
blt2ski's Avatar
Here is a picture of the two tracks I have, one on the cabin top, the other on the deck behind, ie rear ward of the side shrouds.
Sailnet and it idiotic write word and it goes to sailnets store..........."http://www.harken.com/fur ling/Carbo_Racing_Foil.php" hopefully that will work. You will need to copy the info in the parenthesis, and delete the space between the "fur ling" and that will get you to the harken site! I hope.............
When Alex gets to reposting, I am sure what he will show/has will be different, but similar in how it works etc.
Marty
She drives me boat,
I drives me dinghy!
blt2ski is offline
post #34 of 41 Old 01-26-2009
AdamLein's Avatar
It worked. And, O, brave new world that has such sailing gear in it. This little toy seems too good to be true?
Anyway thanks for the photo. I see a short rail on the cabintop and one on the side deck... do you have a third on the toe rail? I've got a similar setup, but always assumed the cabintop rail was for a tweaker.
AdamLein is offline
post #35 of 41 Old 01-26-2009
blt2ski's Avatar
My upper track is for my 110 only, or possibly a smaller say .7-.90% head sail. The lower track is what came with the boat, sorta kinda........That track you see is actually new last dec with line control carrs. My old original track was about 6.5' or 2Meters in length, the new one is 8', so I now have a bit more forward for running/reaching use with the larger LP jibs. Including my 110 if I wanted to in windier conditions for a bit more off wind use vs the upper ones I can get to within 8* or their abouts vs 10-11* for the lower tracks.
A tweaker is usually a differnt setup, with a line and a metal loop, so that you can move the sheet inward a bit more than what is normal with the tracks.
I thought I had a better picture looking back with both tracks, but am not finding it. I need to setup this, but my sheets are able to run to the back of the cabin top for the 110, but need bigger winches to make this work. In the mean time, I find running the sheet line from the upper tracks to the lower then back to the 40's for the genoa work better than the 16's I currently have on the cabin top. Plan is to move the 16's inward, and put 24's or 32's on the outside for the 110 and smaller jib work and the bigger jibs use the lower tracks. My HS's consist of currently an original 135, a new carbon 155, and a dac/mylar 110 and a storm jib. the end of next month I have a replacement 140 for the 135, and a 130 reacher for the less than 7-8 knot wind days here in puget sound for summer racing to catch the zyphers my 155 will not.
Marty
on edit.....
The line you see just towards the mast from the upper track, what I am realizing you may see as a tweaker, is my AS tack line!
And a link to another forum thread with how I installed the new lower tracks, there is also a copy of it on another thread here at sailnet, but not sure where it is at.
She drives me boat,
I drives me dinghy!
blt2ski is offline
post #36 of 41 Old 01-26-2009
blt2ski's Avatar
Adam,
Another note, Schaefer or Lewmar, can not remember which, makes a foil similar to the harken one. I put on a harken, or my use application thought it was the best bang for the buck, along with most of the upgrades from the OEM Goiot stuff has been harken. Don't feel that the only option is the one I used.
marty
She drives me boat,
I drives me dinghy!
blt2ski is offline
post #37 of 41 Old 01-26-2009
I will have to remember the term "peal" thos! thank you!
Marty
The term "peel" typically refers to hoisting one spinnaker before dousing the first one.. but the concept is, of course, the same. As to foil-set genoas we've always simply referred to sail changes e.g. "gotta change down to the #3", with hanked-on sail changes referred to as "bare headed" - since you cannot avoid a period of time without a headsail up or drawing.
Doing "peel" type genoa changes with a luff foil works really well, but calls for some forethought with regard to keeping the halyards organized so they don't cross during the sail changing procedure, know which "groove" you're in so that you can mostly plan to hoist a new sail in the windward groove while still sailing on the first genny. Then throw in a tack, sheet home the new sail, and now the to-be-dropped headsail is to windward and while dropping falls nicely onto the deck.
Of course all this is discussing a racing foil, not a furling foil since the swivel cannot drop if another sail is in the groove.... Headsail changes on furlers are bare headed ones too.... That said, the higher end furler have removable split drums allowing them to be converted to "racing foils" with the swivel simply left to sit at the bottom of the foil.
The main advantage of hanked on sails is that they are well-held on board by the hanks. Luff tape sails are only held by the three corners once down - takes more manpower to keep large parts of these sails from slipping overboard if mishandled. A section of a genny falling overboard and filling in the water can easily tear a stanchion out (or at least bend it)
Sorry for the lecture.. most of you don't need it, but some may find it new to them and helpful!
Faster is online now
post #38 of 41 Old 01-26-2009
blt2ski's Avatar
With all of Mr Fasters lecture.........have we gotten off topic, or have we gotten off topic!.......... at least it is still sailing oriented?!?!?!?!?!
She drives me boat,
I drives me dinghy!
blt2ski is offline
post #39 of 41 Old 01-26-2009
With ..Faster's lecture.........have we gotten off topic, or have we gotten off topic!.......... at least it is still sailing oriented?!?!?!?!?!
Hey.. the first word in the thread title is genoa......
post #40 of 41 Old 01-26-2009
Thank You!
You guys are the best...that is a great tip and makes so much sense.
outthere09 is offline
Genoa rigging question from a newbie PotterSquatter Introduce Yourself 6 11-30-2008 03:55 PM
I fully disagree to Raymarine ..... negrini Gear & Maintenance 19 04-06-2008 02:09 AM
Genoa sheets calamitas General Discussion (sailing related) 2 08-28-2007 01:27 PM
Seven Knots You Can't Live Without Sue & Larry Learning to Sail Articles 0 11-14-1998 07:00 PM
Seven Knots You Can't Live Without Sue & Larry Seamanship Articles 0 11-14-1998 07:00 PM
