Old 01-23-2009
Genoa sheets knots, tip for newbies
OK, here is a cool tip for newbies and others...off course my expereince, and nothing other, many may not agree, I don't mind.(or care)
One of the first things we learn once you start operating in the bow of boats is the knots that tie the genoa sheets to the sail..so far so good
Most people, just tie a bowline or any other similar knot, and many many tie the knot as near and short as possible..see bellow
well I don't do that, and so no one I know. I normally tie the knot as long as possible, (see blue arrow bellow, I will explain why...
but the loop can't be too long, as it may prevent the sheet to get in the genoa track car sheave. The knot should be at least 3 inches before it reaches the sheave.See red arrow above
WHY??
Well one of the main reasons is that in a storm, in a hurry or any other emergency, the longer the knot is from the sail, the further in it is inside the boat, so one does not have to expose and stretch outside the boat to reach the knot in an emergency, which is good in bad weather..one never knows..
When one needs to untie the knot, and the sail is flapping around, it's hard to hold on to it...by having a long loop it dampens the flapping stoping the knot from shacking with the sail
It also helps when setting the wisker pole on a downwind, as the loop facilitates the manouver, and other more stuff...
Hope this tip from uncle Alex has helped you
have fun
Old 01-23-2009
... and a longish knot tends to slide around shrouds and stays with less hangups than a short chunky one.....
right Unk?
1984 Fast/Nicholson 345
Old 01-23-2009
Fast, yes,
Another advantage is on rolled genoas, the knots make it easier to reach the sheets, when and if needed.
Here Fred, a relatively short person (still), can reach them easily, as can be seen.
As can be seen bellow in this photo, both knots are inside the boat, even with the sail outside.
And I do that with the Spinnakers also.
But with the Spinnakers, I use a thin Dyneema extension line that reduces weight suspended on the sail, and allows me to remove the sheets easily and have both allways attached, but above all reduces friction on forward rotating gybes by less than half once the sheets pass the in front on the genoa tack.
hope this helps,
thanks
Old 01-23-2009
smackdaddy's Avatar
Last Man Standing
Woah, woah, woah. I have a parrothead/larkshead/chucklehead/whatever "knot" in my Genny using a single sheet. Is that sheer lunacy? Am I begging for disaster? Will I sink?
Giu - the avatar. Sweet!! And you're complaining about mine? Yours is just freaky, man! Love it!
Old 01-23-2009
Abysmally Stupid
jorgenl is on a distinguished road
Thanks for the tip Uncle A,
On our Thursday night races I seem to be tasked with poling out the genny and it always takes me three attempts (not so coordinated )
We always do less well on the downwind legs...
We shall try the longer bowlines next season.
Old 01-23-2009
justified is on a distinguished road
Great ideas! can't wait till the white stuff disappears and I can try those out.
SPRING IS COMMING!!!!
Justified
Old 01-23-2009
Just one comment about long knots on Spinnakers.. I assume this is in reference to an A sail. While few symmetrical spins are tied on, if they are then long knots are problematic when acting as a guy vis-a-vis the pole. The tack/clew should be as close to the pole as possible for stability.
Old 01-23-2009
xort has a spectacular aura about xort has a spectacular aura about xort has a spectacular aura about
Thanks Uncle Al
Uncle Al, the kiddies pal!
Old 01-23-2009
citation34's Avatar
citation34 is on a distinguished road
Geez, Giu. Is winter getting to you, too? I tie my bowlines long, too. Finally, I got one right! Wish Michigan had Portugese(sp?) weather.
Mark
wish you well
'Liberty' Citation 34
Old 01-23-2009
denby's Avatar
Location: Dead Sea, some times called Long Island Sound
denby is a jewel in the rough denby is a jewel in the rough denby is a jewel in the rough denby is a jewel in the rough
Thanks for the tip Unk. Will try it out this summer.
Dennis
O'Day 302
Be careful or i will do what the voices tell me to do
To get the most from Sailnet, follow the link in
's signature.
Hey stuffit "Get a life"
Genoa rigging question from a newbie PotterSquatter Introduce Yourself 6 11-30-2008 03:55 PM
I fully disagree to Raymarine ..... negrini Gear & Maintenance 19 04-06-2008 02:09 AM
Genoa sheets calamitas General Discussion (sailing related) 2 08-28-2007 01:27 PM
Seven Knots You Can't Live Without Sue & Larry Learning to Sail Articles 0 11-14-1998 07:00 PM
Seven Knots You Can't Live Without Sue & Larry Seamanship Articles 0 11-14-1998 07:00 PM
