Well my day really sucked. - Page 13 - SailNet Community
 2Likes
post #121 of 445 Old 03-08-2009
okay as far as "attaching" the barrels. i would thread a rope under the hull tied like an inverted Y to each barrel ( like an anchor bridle on a cat ) and use a trucker hitch to tie it to the toe rail on the high side. this will allow you to pull them further down, using the hitch like a come along as the boat rises. i would also get some cheap ratchet straps from harbor freight and run them around the hull and the drums, you can extend them with old sheets and halyards to lock them in place.
the idea being the inverted y will stop them from floating up to the low toe rail, and when the boat starts lifting you can pull them down more. then use the ratchet straps to make sure they dont slip off the front or the back.
if there is any wave action there you can use it to, as she starts lifting, if the waves are bouncing the hull/barrels you should be able to get one at a time a little deeper as she bounces
once she is off and floating you can tell sailing fool to
scottyt is offline
post #122 of 445 Old 03-09-2009
Sea Dweeb
RanAweigh's Avatar
We are all pulling for you. Keep at it.
RanAweigh is offline
post #123 of 445 Old 03-09-2009
STARBOARD!!
KeelHaulin's Avatar
Originally Posted by SVDistantStar View Post
Im going out tomorrow at low tide and attach my 7 55 gallon drums to it how ever i can and then see what happens. If i can ever get it turned around, i can pump her.
If you can; rig the drums so that you can sink and then re-float them. The key to getting them to help lift the boat is to force them to displace as much water as possible. If you tie them on while floating alongside the boat you might not get enough displacement to help lift the hull.
To rig them to sink and re-float you would need to run a hose in from the lower port that can allow you to pump water out; and a vent line on the upper port to allow air to flow in. If the drums begin to crush in from the loading you may need to use compressed air to pressurize the air inside the drums.
KeelHaulin is offline
post #124 of 445 Old 03-09-2009
not Sully or Dandelion
She will come back up somehow, im not leaving her out there to die. I already lost one boat before, and thats not going to happen again.
Good luck man.
As others have said. Get the drums as deep as possible.
Get the boat as light as possible. Take off boom, doors anything to get her more buoyant.
MorganPaul is offline
post #125 of 445 Old 03-09-2009
djodenda's Avatar
We're still on your side and cheering you on!
David
David
1987 CS 36 Merlin "Kyrie"
djodenda is offline
post #126 of 445 Old 03-09-2009
Somewhat Senior Member
mgmhead's Avatar
it is my hope that the next time I read this thread there will be wondreful news that Distant Star is afloat. Good luck and best wishes to you...MGM
s/v Rhythm
Catalina 387 #29
Rock Hall, MD
mgmhead is offline
post #127 of 445 Old 03-09-2009
STARBOARD!!
KeelHaulin's Avatar
I think his troubles are more associated with the volume of water inside her. The doors and boom are negligible weight compared to the mass of the hull, keel, and water that is currently inside. As soon as he gets enough buoyant force with the drums to raise the stern the hull should be pumped out (removing the tons of water that will become trapped inside). Getting the water out will make all the difference.
post #128 of 445 Old 03-10-2009
SVDistantStar,
Give it a try, but I don't think 7 drums will be enough to do the job. Someone indicated that a 55 gal drum of water is about 450 lbs. So 7 would give at a maximum 3150 lbs. of bouyant force. Your boat weighs about ~16,000 lbs. not counting the water inside. I think you are going to have to get the cabin sealed off and get that water pumped out. The original pictures seemed to be at low tide and it's hard to tell how much bouyancy you could create at high tide with the boat pumped out. Still give it a try. You might still have to keep her healed over even then to keep the keel out of the mud, as it looks like the winds drove her pretty far up on the shore.
We had another area boat that drug in a storm and went aground on its side like yours on a sand bottom. One of the small contractors that installs small bulkheads and piers got that one off by dragging it. They had a barge with spuds (anchoring poles) and a backhoe. It didn't take too long. At least contact a couple of those types of contractors to see what they would charge. It might not be as much as you expect and they would get the job done quickly...no harm in asking. If you do it with the contractors, make sure you have in writing exactly what it's going to cost you so there won't be any surprises.
Good luck.
NCC320 is offline
post #129 of 445 Old 03-10-2009
STARBOARD!!
KeelHaulin's Avatar
Yes; ~3k lbs of bouyancy if the drums are fully submerged and air filled. The problem is getting them positioned and then emptied of water. 3k lbs of lifting force might be enough to get the stern section and cockpit coaming above the level of the water, which would then allow the hull to be pumped out. Once up and floating it would then just be a matter of dragging her off of the shore; and I agree that adding weight to the mast to induce heel might be a way of "lifting" the keel off the mud.
post #130 of 445 Old 03-11-2009
Capnblu's Avatar
Wouldn't it be easy to screw plywood over the cockpit coaming, and pump out the water? If your boat was holed, wouldn't you try to stop the water from flooding back in before attempting to empty the water? That pump shown in the tender should do the trick. Break the suction of the mud with AIR. Adding water to mud, makes better mud. ever get you boot stuck in real mud? Can't get it out till what happens? (till ya get air in the area of suction) once she is floating, and you need to move into deeper water, PUMP AIR around the keel into the mud and winch yourself into deeper water. I hope this advice has been rendered useless already.
Why, why, why?
I Don't Know! I Don't Know!
Capnblu is offline
Day Three - Post Storm @ Zephyr Sail NewsReader News Feeds 0 04-10-2006 06:15 PM
2006 Optimist Selections - Day 5, Port Elizabeth, ABYC @ Sail Search RSA NewsReader News Feeds 0 04-10-2006 06:15 PM
day charter boat and other stuff Carbonbody Boat Review and Purchase Forum 4 06-10-2004 01:11 PM
