Prop info ... - SailNet Community
Blogs
Old 10-11-2002
Joe Fox is on a distinguished road
Prop info ...
I have an Irwin 31'' sloop with a 15 hp Yanmar engine. The boat has a 2 blade prop, 13 x 13 x 7/8, 3200 rpm @ 6.5 k. I would like info for a 3 bladed prop to increase the speed and performance.
Old 10-11-2002
Senior Nappy Headed Ho
Denr is an unknown quantity at this point
Prop info ...
To increase speed and performance I would suggest a new full battened main (5-7 oz. material) and perhaps a tri-radial 150% genoa; personally, I like the products from North.
Old 10-11-2002
paulk's Avatar
paulk is on a distinguished road
Prop info ...
6.5 knots sounds pretty quick for a 15hp engine on a heavy 31 foot boat. Changing to a 3-bladed prop might add a little speed under power, and it might not; the engine is only so powerful and the boat''s weight isn''t being reduced. The three blades could easily cut sailing speed by half a knot in all conditions. For water-skiing, you''ll need a different boat.
Old 10-12-2002
windship has a little shameless behaviour in the past
Prop info ...
First of all, I agree with Denr''s point.If six and a half knots isn''t enough, get a power boat.
I don''t think your going to do any better.A three blade prop will not give you more speed, but it will move the boat better through wind, seas and currant.Personaly, I think that with a fifteen horse engine and a displacement of nine thousand three hundred,(which is light for a thirty-one footer and IS the reason your getting six and a half)your lucky to be getting the six and a half
Dennis
Zincs for Sail Prop feathering prop jrbarn Gear & Maintenance 4 09-20-2006 11:40 AM
how to remove folding prop? mcagney Gear & Maintenance 1 07-20-2005 11:23 AM
Prop for Pearson 35 gbeardmore General Discussion (sailing related) 2 05-27-2001 01:08 PM
Prop for Atomic 4 gbeardmore Gear & Maintenance 0 05-03-2001 02:15 PM
Prop for Pearson 35 gbeardmore Gear & Maintenance 0 04-24-2001 01:49 PM
SEO by vBSEO 3.6.0
(c) Sailnet 2000-2006
