  #1
Old 10-16-2002
nauticalrich's Avatar
nauticalrich is on a distinguished road
Diesel Oil
Boy am I green.
Universal 14 HP, if it needs a quart of oil what do I put in.
No specs on boat on this.
Does a diesel take special oil??????
  #2
Old 10-16-2002
RichH's Avatar
RichH will become famous soon enough
Diesel Oil
We were ALL green once !!!
Diesels need special additives added to the oil. "Rotella" (is probablly one of the most popular) , etc. or any brand that specifies ''for use in diesel engines''. Most marine diesels use 10W-30 for normal ambient conditions.
  #3
Old 10-16-2002
tsenator is on a distinguished road
Diesel Oil
Do you have an owners manual. that will suggest the correct motor oil. But I would suggest a good quality single weight like 30W specifically made for Diesel Engines (Though I have seen more and more marine diesel manufacturers say its ok to use Multiwieghts like a 10W-30)
Make sure its for Diesels (You can tell its made for Diesels because it will have a API Service category rating on it like "CF" or "CG-4" When you look at the can of oil (as opposed to "SJ" or another "S" rating which is for gasoline engines.)
Here is a little write up on the ratings http://api-ep.api.org/filelibrary/ACF1E1.pdf
Go to your local Marine store and they should be able to set you up. Like the above said "Rotella" is a good brand for marine diesels.
The MOST important thing to do is to change your oil and filter often. Thats the easiest way to help your engine last longer. Every 50-100 hours and at least once a year before you put her away for the winter or store her
  #4
Old 10-16-2002
WHOOSH is on a distinguished road
Diesel Oil
Rich:
You might find this site helpful for servicing your engine:
http://www.marinedieseldirect.com/universal/200157/universal-owners-manual-oil-filter-change.html
I would recommend visiting or calling a shop familiar with Universal diesels and getting their recs on oil choice, especially if you live in a seasonal climate. Alternatively, you could email the folks at the web site above...and maybe even order a shop manual, which will pay for itself in short order.
One grade of oil is not suitable for all engines under all conditions. Best you learn what''s suitable for your location and engine.
Jack
You may post attachments
You may edit your posts
fuel consumption gas vs diesel jklewissf Gear & Maintenance 25 1 Week Ago 07:28 PM
Diesel Stoves santeana Provisioning 6 02-26-2012 05:14 PM
Old diesel obiec Gear & Maintenance 7 11-26-2006 12:26 AM
Diesel Deckplate ERUPTION pma_foyl General Discussion (sailing related) 1 07-06-2004 07:16 AM
diesel tachometer diesel MHRitter Gear & Maintenance 1 09-17-2002 11:52 AM
SEO by vBSEO 3.6.1
