03-15-2009
I don't think a swamp cooler would help much. The 12 VDC fans, like the Hella Turbo or Camframo are the way to go IMHO. Quiet, low voltage draw... the main problem is if the air is static...it tends to get nasty... if you keep the air moving, and these fans will do a good job of that, even really hot, humid are becomes tolerable.
