Old 03-18-2009
christsake is on a distinguished road
rudder repair
My rudder looks like crap on my 37' Irwin. I was going to swap it out with my neighbors 37' Irwin, but if he ever found out I'd be toast. So it looks like I'm stuck and will have to repair it.
Last year I smoothed most of it out, then bondo'd the gully's and faired it out. Son of da beech if that didn't seal the sucker up tight ad a drum, cept for the hole somewhere at the top. The water sank to about a foot above the bottom, froze, which expand3ed it and cracked it in a straight line from front to back on one side.
The water drained out. I called Foss and they told me what to look for and it appears it's their rudder. They told me I could remove the outer skin and reglass it and it will be fine. Other "people" said why bother? Fill in the crack and go sailing!
Votes needed as to what to do.
The future...I would like to sail to the Caribbean in a few years, so I figure I either fix it right this year, or pay the piper later on. Oh yeah, I sail in Lake Erie. And the foam appears to be in good shape...Foss told me if it's mostly all together, I could fill in the divots and gaps to fair it out, then glass it.
Old 03-18-2009
MSter's Avatar
Salty
MSter is on a distinguished road
Seal the crack and keep her in warm water! It almost sounds as this reply could fit another thread.... ;-)
MSter
1979 Irwin Citation 39
Dragonfly II
Old 03-18-2009
patrickrea's Avatar
patrickrea is on a distinguished road
Reglass. DIY project.
Patrick Rea
1978 30' Hughes Northstar 1000
1964 20' Bertram Moppie
Old 03-18-2009
The question is how much is the rudder's internal structure damaged? If it isn't then closing it up and re-glassing it isn't an issue...but if the interior web or stock is corroded, it may need replacing. You really should take it apart and inspect it all.
Old 03-19-2009
svHyLyte's Avatar
Old as Dirt!
svHyLyte is on a distinguished road
Foss Foam Rudder Repair
You may find the following helpful: Possible Rudder rebuild questions - Page 3 - Cruisers & Sailing Forums . You can review the whole thread but I suggest you begin with post number 39.
s/v HyLyte
Old 03-19-2009
I'm learning:
Foss rudders need to be white so as to not absorb the suns rays because heat destroys the foam inside.
The foam in mine is fine. I drilled three holes and nothing came out and the skin seemed to be welded to the foam..there was no void.
The rudder is coming off and will be recoated with a new skin.
Lastly, I read where a bump such as what I had on the Starboard side can cause the boat to not point into the wind properly.
So Off she comes!!
Now, how do I raise a 20,000 lb boat on a cradle?
Old 03-19-2009
tommays's Avatar
diging a hole is best IF they let you
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
Old 03-20-2009
Birdface's Avatar
Northeast 25 O'day Owner
Birdface will become famous soon enough
After losing a rudder in the middle of the ocean I will tell you to fix this entirely or get it entirely replaced.
Leave no air-pockets and be sure it lays up completely.
I got my replacement rudder double thick.
1976 25' O'day - "SeaWind"
Hello Sailor: "I've just learned that good boats, in good hands, are damned robust creations."
Building a Rudder Newport 30 Armchairprotest Gear & Maintenance 5 04-07-2009 01:11 PM
Emergency Steering John Kretschmer Seamanship Articles 0 03-08-2002 07:00 PM
Emergency Steering John Kretschmer Gear and Maintenance Articles 0 03-08-2002 07:00 PM
Emergency Steering John Kretschmer Cruising Articles 0 03-08-2002 07:00 PM
Rudder Problems Mark Matthews Gear and Maintenance Articles 0 02-13-2002 07:00 PM
