01-20-2010
There is nothing surprising about this at all. It is a very well known fact that multihulls require much heavier standing rigging than monohulls. This is also the reason the sails on a multihull are usually heavier weight than similarly sized sails on a monohull. This is less the case on trimarans, which will heel a bit more and aren't as stiff as catamarans in general.
Regular inspection of the rigging is a must...but some commerical entities often skimp on it, not realizing the importance of it. I would guess that the rigging on those you mention failed at the bottom, not at the top. The top rigging is often in far better shape than the lower rigging, since it isn't exposed to constant spray and salt the way the lower rigging is.
Originally Posted by tweitz
On catamarans. There is an interesting article in Soundings about the USCG finding a number of rig failures on registered passenger carrying catamarans and ordering extra inspections. The speculation is that most of the cats in question are in warm climates, like Hawaii, get a lot of year round use and rarely have the mast dropped for inspection of the standing rigging. The part that was nost interesting to me is that the CG thought one issue is that on monohulls the heeling of the boat will ease the stress on the standing rigging, whereas multihulls are so stiff that the stresses are higher. It seems like a problem as much of maintenance as design and curable by building heavy enough rigging and inspection, but I never would have thought about requiring stronger rigging in cats before I read the article.
