- Quick Menu
04-21-2009
Unnecessary rescue efforts . . . . . again
Another case of premature action on an EPIRB.
A yacht some 200 nm north of New Zealand set off an EPIRB. The local SAR despatched an Orion search aircraft as well as diverting a Mearsk cargo vessel to began the hunt for them.
I heard a report on local radio today that said the vessel had experienced bad weather and had "damaged their sails" so they decided to set off the alarm. It has apparently been further confirmed that the vessel was otherwise undamaged and had enough diesel on board to motor all the way to NZ.
Go figure.
Arthur C. Clarke
04-21-2009
Main Entry: panic  !pa-nik
Pronunciation: \ ˈpa-nik \
Function: adjective
Etymology: French panique, from Greek panikos, literally, of Pan, from Pan
Date: 1603
Results
| 1. | 1 of, relating to, or resembling the mental or emotional state believed induced by the god Pan - panic fear
| | 2. | 2 of, relating to, or arising from a panic - panic buying
| | 3. | 3 of or relating to the god Pan |
Most people don't know the origins of a Pan-Pan Radio call either!
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Never Forgotten
04-21-2009
The captain and crew should be ashamed and forced to pay for the cost of diverting the Maersk cargo ship and the Orion SAR aircraft's time.
04-21-2009
At best, that is a PAN-PAN, although "damaged sails" shows a lack of seamanship in my view, because if your mast is still secure, you can rig almost any scrap of sail to get 200 miles...it's just going to take three days!
As far as I am concerned, you activate the EPIRB by chucking it on a line from the liferaft after your boat's sunk OR if someone's smashed their skull or had a heart attack or something. Imminent danger to life...not "my boat's no longer convenient".
Can't sleep? Read my countdown to voyaging blog @ To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
04-21-2009
Unfortunately, too many sailors today, see inconvenience as a life-threatening event...
04-21-2009
It's easy to act tough when you are at a desk typing on a computer! Perhaps the people feared for their lives, one does not know the circumstances.
04-21-2009
Super Fuzzy Moderator
True enough I guess but an Epirb is an electronic SOS.
Frightened you may be, yea even scared witless, but it's not a good enough reason to issue a May Day. A Pan Pan yes , but not a May Day.
Valiente is quite correct, as you step off your boat into your life raft , that is the time to set off the Epirb.
If you are going to call in the heavy duty support network you need to be in real danger and I'm sorry but when you have a mast and a scrap of cloth you are not in a hopeless situation. (Presuming a reasonable amount of searoom.)
04-21-2009
They had enough fuel to get to a safe harbor. They had not been knocked down. They had not been holed or taking on water. AFAIK, there was nothing wrong with their boat except the sails were damaged. No was was injured AFAIK. Exactly what were they pulling the EPIRB trigger for???
The only thing an EPIRB should be used for is the equivalent of a MAYDAY...not a PAN PAN, not a SECURITÉ. If they can't take a bit of heavy weather... maybe they shouldn't be out there.
04-22-2009
Heard on our local radio station this morning that the three people aboard had been air-lifted off the vessel - don't know what the fate of the vessel was - hope it was scuttled.
Purely speculation but I think the folks on board had "had enough", the helo was out there so they bailed. If I hear anything to the contrary, I'll post it here.
Arthur C. Clarke
04-22-2009
They need to harden up and read Miles and Beryl Smeeton's 'Once is Enough'
| Thread Tools |
Search this Thread |
