Old 04-24-2009
wbcj44 is on a distinguished road
Need help
I accidentley rolled up my jib without the sail on it. How do I get it down so that I can put my jib back on?
Old 04-24-2009
LarryandSusanMacDonald's Avatar
SaltwaterSuzi/CapnLarry
LarryandSusanMacDonald will become famous soon enough
Not sure I understand the question. Did you pull up the halyard?
Saltwater Suzi and Cap'n Larry
"A sailboat is a fickle mistress. You’ve got to buy her things. You’ve got to understand everything about her. What you don’t know she’ll use against you." -Captain Larry
Old 04-24-2009
CharlieCobra's Avatar
On the hard
CharlieCobra has a spectacular aura about CharlieCobra has a spectacular aura about
If you hoisted the halyard up the mast without a sail and the mast is fixed, as on a bigger boat. You're just gonna have to go up the stick after it...
Old 04-24-2009
T37Chef's Avatar
Senior Culinary Member
T37Chef will become famous soon enough
Just flip it over under and over, then you should be able to put it back on, piece of cake!
Shawn
S/V Windgeist
Tartan 37C #358
Photo by Joe McCary
THE Yacht Builders List:
Useful Food Purchasing Links:
Old 04-24-2009
Not sure what you did??? Can you elaborate? How do you roll up the jib without the jib on it... the jib is the sail??
Old 04-24-2009
AdamLein's Avatar
AdamLein will become famous soon enough
My guess is that he pulled the furling line out of the drum? The solution would be... feed the line back around the drum by turning the drum by hand?
edit: on second read, the halyard interpretation seems more likely.
s/v Essorant
1972 Catalina 27
Old 04-25-2009
Last season as I was taking down my sails for winter storage, I removed my sails and accidentally rolled up the the halyard to the top of the mast. Now as the season is beginning, I realized my mistake and cant figure out how to get the halyard down so that I can put back on my jib.
Old 04-25-2009
Not sure what you meen when you say flip it over. Can you please explain?
Old 04-25-2009
Last season, as I was preparing my baot for winter storage, I was taking off my sails when I rolled up the halyard after I removed my jib.
Old 04-25-2009
Ahh... you accidentally let the halyard go up the mast... well, unless you can drop your mast, it is time for you to learn how to use a bosun's chair. Don't try going aloft unless your boat is IN THE WATER.
