Old 04-30-2009
SteveA's Avatar
SteveA is on a distinguished road
Sliding Gooseneck
I recently bought a Ranger 26 that someone has set up with a sliding gooseneck. I've never sailed on a boat with a sliding gooseneck before.
Am I right in thinking that adjusting the downhaul for the gooseneck does the same thing as adjusting a cunningham, but without putting a wrinkle in the mainsail at the tack?
It seems like by adjusting both the gooseneck position and the halyard, it's possible to slightly change the mainsail's position along the mast. Is there any advantage to that?
Old 04-30-2009
celenoglu's Avatar
celenoglu is on a distinguished road
A sliding gooseneck is similar to a cunningham. The wind speed increases as the altitude from the sea level increases. The wind speed is defined as the speed 10 meters above sea level. Therefore raising the sail higher will have an effect on driving force. But this will be minimal due to a very small increment in height.
Old 04-30-2009
You do have to remember that while raising the sail will give you a tiny bit of extra drive, it will also increase the heeling moment of the sails, by shifting the COE upwards slightly.... The range of adjustment isn't really enough to bother mucking with. The sliding gooseneck is just an alternative to a cunningham, that is aesthetically a bit more pleasing if a bit more mechanically complex.
Old 04-30-2009
14432's Avatar
14432 is on a distinguished road
A sliding goosneck also allows you to hoist the main those last few inches relatively easily and then adjust the luff/halyard tension via a multi-purchase system below the boom.
Gooseneck Corrosion DRM Gear & Maintenance 4 06-24-2010 06:05 AM
Sliding Genoa/Jib track block Petar Seamanship 21 03-26-2009 12:26 PM
Gooseneck Height Problem zaldog Gear & Maintenance 5 07-21-2007 07:53 PM
Sliding hatch question. C27Shockwave Gear & Maintenance 3 12-21-2006 08:17 PM
Pearson 30 gooseneck bobcarter Gear & Maintenance 2 04-12-2006 04:11 PM
