Over reliance on electronics - Page 4 - SailNet Community
 33Likes
post #31 of 61 Old 12-20-2012
Omatako's Avatar
Re: Over reliance on electronics
Originally Posted by travlineasy View Post
It never ceases to amaze me how many individuals pooh-pooh advancements in navigation, something that has likely happened since the invention of the compass.
Gary
Gary
I don't believe there is more than 0.002% of the members of this forum who still regularly use a sextant or depend on it for their navigation. I know I don't. So in essence they (we) are not pooh-poohing the use of electronic navigational aids.
The OP posed the question: Is there over-reliance on electronics. Well yes, I believe there is. Simply because I see folks who have bought boats and they learn how to sail and then begin to plan their offshore trips to the islands.
Amongst the things they consider important are watermakers to feed the automatic washing machine and inverters big enough to drive the microwave and hair dryer.
And when you ask them of their navigational training, the common refrain is "we have a top-of-the-range chart plotter, we have AIS and we have a 3D colour radar, what more do we need?"
Well, I just find that a little scary because all of those things rely on electricity and that is one of the less reliable supply lines on any boat. If I had to make the continued safety of people on my boat dependant on the continued supply of electricity I would consider myself very irresponsible. And with all your immediately updating charts on the chart plotter you are reliant on that unstable system.
It's like I said on a thread elsewhere - what are you going to do when that beautiful screen goes black? And with respect, only very naive boat owners believe that it can't. From your first post I gathered that EVERY piece of information on your boat will soon be presented to you on one display. Really - good luck with that.
Oh, and by the way, good luck also with well-managed cross track error information that helps you sail down the rhumb line - many other boats/ships with fancy chart plotters will agree with you and are doing the same thing.
Arthur C. Clarke
Omatako is offline
post #32 of 61 Old 12-20-2012
travlin-easy's Avatar
I agree with much of what you stated above. In my case, if the screen goes black, it's not a problem - I switch on one of the 2 backup GPS/Plotters I have onboard. If all three go dead, and all 5 batteries die, I'll reach on the bookshelf and pick out the appropriate chart book(s). Yes, I have, and use paper charts, mainly in conjunction with the GPS/Plotter. As some stated earlier, they provide me with a big picture, but zooming in with a paper chart is not a possibility. Granted, some have insets, but they too are limited.
Cheers,
Gary
travlin-easy is offline
post #33 of 61 Old 12-20-2012
Sorry MILUTIN, didn't follow your post properly. The attached blog made things clearer.
chamonix is offline
post #34 of 61 Old 12-20-2012
The most female moderator
Donna_F's Avatar
Dock
Your cockpits can look like Starfleet command if you want, just remember to raise your heads once in a while and look around you. Too many times I see boats motoring past us and the helmsman never looks up from his electronics. Not to mention the time a boat went by on autopilot and there wasn't a helmsman.
Donna
Catalina 30 TRBS
Rock Hall, MD
KB3ZCB
Donna_F is offline
post #35 of 61 Old 12-20-2012
I think all skippers should be confident navigating traditionally.
However the reality is that mapping and GPS systems, frequently with independent battery supplies, are becoming very cheap and multiplying rapidly.
I seem to accumulating 2-3 GPS units a year, many with built in maps. Some precaution concerning lightening strikes needs to be considered, but given the multitude of GPS units storing a couple in a faraday cage is sensible.
As a cruising boat I currently have 12 GPS units and 8 electronic mapping systems. 9 independent battery systems.
Could all these GPS and mapping systems fail? Certainly, the sea is a hard environment. However I have far fewer backups in the event of rudder failure, hull strike, fire etc etc.
I don't lay awake at night worrying about GPS failure. Navigation without GPS is not difficult. Managing a boat without a rudder, or rig, following a fire, or with a hole below the waterline even MOB. These are the important catastrophic events that pose a real risk to my vessel and perhaps my life.
Sure, I could stuff up navigation and end up hitting rock, but I fail to see how turning off the GPS decreases the risk. Removing a valuable source of navigational information could only increase, rather than decrease the risk in my view.
chef2sail and kellysails like this.
noelex77 is offline
post #36 of 61 Old 12-20-2012
Count me among the 0.002%
Why,
Because I like to, and I'm good at it.
Dick
Flybyknight is offline
post #37 of 61 Old 12-20-2012
MarkofSeaLife's Avatar
Dock
I think thats a load of bollocks. (Thats my fav word of the day. But just today)
Teaching people the old outdated school like sextant sights just bores the student. It needs to be kept relevant.
Compas swingers are a thing of the past because a compass doesnt need to be accurate anymore, its just a reference, an approximation, good enough for emergency.
Now courses should covering, not to a proficent level as in the past, getting to a port in case of an emergency. That uses differenct techniques that can be learned basically. Things like you are off the east coast USA in June. West is where the sun sets, go west, when you see land, if no visual identification, wave madly, wait for a ship and follow, vhf the Coasties etc. one doesnt need to have precise L&L and make it to the exact destination, one merely needs to get to a safe port.
As the older lot of sailors die and theres generational change the rediculousness of the paper/non ecn position will be come irrelevant. All cell phones will have GPS, all will probably be Satellite connected, all wil have world maps available without cell connection (with Advertising!!!!!). Big brother will know where you are anyway with his chip up your bum.
The last bit of paper has left the modern world of aircraft, space flights, science, and even literature. Ask and author to write a page with a pen and his hand will be shakey, the prose weak and sentences wrong, but give him his computer and his words will flow.....
Damn it! I have to go! My refrigerator with its internet connection has listed my days social events! I am meeting 3 (three!) females all with huge gazooballys!
Mark
Sea Life
Notes on a Circumnavigation:
MarkofSeaLife is offline
post #38 of 61 Old 12-20-2012
Omatako's Avatar
Can't say I support that. Getting a fix on a GPS is easy, quick and generaly very reliable so to learn how to effectively do celestial nav in these times is, to me, a waste of time. If you have it and use it as a hobby and maaaaaybe in an emergency that's cool but starting now? No, I don't thinks so
That level of redundancy is extremely rare on any boat - I'd be interested in what the 9 independent battery systems you have look like.
I can't recall it ever being suggested that switching a GPS off decreases risk. If there is an immediate need for navigational information, have it on by all means but tell me how, when you are 1500Nm from the nearest GPS-related thing (land), does having a GPS permanently on reduce risk?
Arthur C. Clarke
Omatako is offline
post #39 of 61 Old 12-20-2012
"but tell me how, when you are 1500Nm from the nearest GPS-related thing (land), does having a GPS permanently on reduce risk? "
Is that a trick question?
You see, if you have the GPS turned off, and your boat is abducted by a UFO or vortexed through the Bermuda Triangle, and suddenly you are dropped off near a rocky lee shore, having the GPS ON will give you that valuable warning that you now are in the wrong place at the wrong time.
If you had your GPS off, you might notice the bright lights and spinning needles, but you'd have no idea how much imminent danger you were in.
What, it never happened to you?
chef2sail likes this.
hellosailor is offline
post #40 of 61 Old 12-20-2012
KNOT KNOWN
Capt.aaron's Avatar
Mark
The proof is in the putting Mark. Your track record of miles speaks for it's self. One does not need to now how to Navigate to sail any more. Boat's sail them selves these day's. Cars Paralell park them selves, Microwaves cook pre-prepared meal's. Men don't need to know how to please their wives...the majic of electronics! I supose you are right about the future, I remember my little sister could'nt tell time on a clock that was'nt digital. I bet you are a better navigator then you let on. I just aquired my commercial radio operaters lisence, and that will be uselees some day with satalite phones. I think it's sad. I pride my self in my self sufficiancy. I don't need thousands of technitions, factory workers, and systems operaters to get up and go to work so I can cross an ocean. I need wind and the magnetic pull of the earth, and even that is'nt totally necasarry, because as you say, the sun goes up and down and Pleadeas alway's points east. I've never seen someone so proud to not know something, but some how (and you are the first), I find it humorously charming. Only because you've proven to be rather salty.
MarkofSeaLife likes this.
" Some are boat wise and some are other wise"
Capt.aaron is offline
mounting nav desk electronics janders Gear & Maintenance 16 03-05-2009 11:30 AM
Electronics show warns fear* of change could hobble industry (The Manila Times) NewsReader News Feeds 0 01-09-2007 10:15 AM
Electronics Box overhead atennaro@optonline.net Gear & Maintenance 0 02-24-2006 10:09 AM
Marine Electronics For Dummies Bluesmoods General Discussion (sailing related) 4 04-09-2003 03:19 PM
Marine Electronics For Dummies Bluesmoods Gear & Maintenance 1 04-07-2003 11:56 AM
