awlgrip - SailNet Community
post #1 of 6 Old 11-10-2002 Thread Starter
awlgrip
I''m wondering if anyone has any experience with awlgrip paint. I have a new boat this year with a factory applied dark blue awlgrip hull. It looks great however now that we''ve pulled the boat for the season everwhere where we''ve had a fender the shine is gone. This boat is washed weekly and sailed on a regular basis. I would think this tough finish should be able to withstand a clean fender rub. Any comments? P.S. even the side of the boat with a fender and no dock shows loss of gloss. Gary
ksmo62 is offline
post #2 of 6 Old 11-10-2002
moderate?
camaraderie's Avatar
awlgrip
Gary... I have similar problem with my blue hull (Imron). Whatever you do ...don''t wax it! Wax will haze and fade. I''ve had good luck with 3M''s Finesse-it. which is a lot of work to apply and buff but gives a nice gloss again. Best...GB
camaraderie is offline
post #3 of 6 Old 11-10-2002
paulk's Avatar
awlgrip
Part of the problem is that even "clean" fenders aren''t, and end up sanding down the finish due to airborne grit and (unless you''re on a lake) salt crystals. Gelcoat, even faded, seems to be a tougher surface than awlgrip. Our awlgrip looks so poorly now (at 12-15 years old?) that Finesse doesn''t do much, and we''re having it repainted. Based on your input, we may get fender covers for when we go to the dock next season.
paulk is offline
post #4 of 6 Old 11-11-2002
awlgrip
Finesse-it works well but shouldn''t be necessary for the overall boat for a number of years (depending on your local conditions). I suggest you contact the builder. Perhaps they did not apply the proper thickness of paint. AwlCare is a good product to apply that can extend the life of the paint. I am also very pleased with AwlWash as a detergent.
dpinorm is offline
post #5 of 6 Old 11-28-2002 Thread Starter
awlgrip
Thanks for the info. We are in the process of checking with the Tartan Yachts who painted the boat and US Paint for their input. Gary
ksmo62 is offline
post #6 of 6 Old 11-29-2002
awlgrip
Try cleaning with a vinegar solution. Worked on my friend''s imron job on his liveaboard. Salted up on the windward side of the hull and nothing would remove it.
VIEXILE is offline
awlgrip dman Gear & Maintenance 10 10-03-2009 10:23 AM
Awlgrip care owlmtn Gear & Maintenance 6 04-25-2005 08:17 AM
New Awlgrip Paint Repair eyebbober Gear & Maintenance 1 10-02-2004 05:17 PM
1 Party poly over Awlgrip? VIEXILE Gear & Maintenance 3 07-18-2003 10:44 AM
awlgrip ksmo62 Gear & Maintenance 2 11-17-2002 07:43 AM
