06-03-2009
"blew the .5 Amp fuse that was in line on the yellow wire. A friend suggested using a 1 amp fuse instead. I did this and it solved the problem. Is this a good idea? "
In a word, no.
Either something was set up wrong in the installation, or the maker screwed up in shipping a 1/2A fuse. If the problem is the installation, you'd want to know what that is and fix it properly. If the problem is the maker...You'd still want to know if you can trust the radio not to catch fire sometime from another problem.
Sometimes, some very rare times, fuses are defective and they simply blow. The vast majority of the time, they blow because something is WRONG and putting a penny in the fusebox (or a higher rated fuse) is simply a good way to make the wire it was protecting overload and catch fire.
Odds are you can get away with it, but do you want to play the odds at all?
