Old 06-06-2009
labestia is on a distinguished road
Keel Hull Joint Separation
Hello:
Is it acceptable to see a line on the bottom paint where the keel joins the hull?
I assume that there has to be some motion at this joint but how much?
La Bestia
Old 06-06-2009
US27inKS's Avatar
Midwest Puddle Pirate
US27inKS has a spectacular aura about US27inKS has a spectacular aura about
Most boats have fairing filler at the hull to keel joint. The keel is usually just a bit smaller than the hull, and filler makes the transition smooth. As the filler ages it will tend to crack at this joint. Many manufacturers us inferior filler for this purpose as well, in many cases Bondo. You can grind out the crack and refill it with epoxy thickened with microballoons for a 1 or 2 year fix. The only way to fix it right is going to be removing the old filler and refairing the joint with epoxy and microballoons. It's a bigger job than it sounds like, but you won't have to mess with it again for quite a few years.
John USYacht 27 "Cora Lee"
Old 06-06-2009
Leither's Avatar
Retired and happy
Leither is on a distinguished road
I agree with John, but it would also be worth while checking the keel bolts to make sure that there isn't a problem, and everything is nice and secure.....
Stuart
Leith (rhymes with teeth) is the port of the City of Edinburgh in Scotland. A Leither is someone who comes from that area.
I must go down to the sea again, to the lonely sea and the sky - I left my shoes and socks there, I wonder if they're dry?
Tips For Compound, Polish & Wax Maine Sail Gear & Maintenance 172 1 Week Ago 05:50 PM
Ryobi vs. Makita vs. Poliglow?? CLucas Gear & Maintenance 61 3 Weeks Ago 06:02 AM
Fin Keel or Shoal Keel acmecoyote General Discussion (sailing related) 11 05-06-2011 04:39 PM
My First Boat...Boat Term Question... Kacper General Discussion (sailing related) 38 09-23-2008 06:52 PM
Wing vs Fin Keel pixurman General Discussion (sailing related) 10 05-28-2004 04:01 PM
