06-07-2009
There are probably two things going on... first, the depthsounder probably has some dampening in the readings to prevent wild fluctuations. Second, being a relatively heavy displacement monohull, you may not be seeing the changes since the boat doesn't really rise and fall with each wave... since the boat is too heavy to respond quickly to a rapid rise or fall due to inertia.
While any given wave or swell pushes up on the boat, it would have to accelerate the entire mass of the boat to get it to move the four feet it rises in the short period of time it is actually under the boat, which is not gonna happen.
