Old 06-13-2009
Paolaa is on a distinguished road
Uuuuoooo - Help with the SSB receiver
Hello!!!
Í´ve just bought a Sony World Band Receiver ICF-SW7600GR, but I cannot receive any under SSB.
What antenna can I put to hear something?
Thanks
Paola
Old 06-13-2009
k1vsk will become famous soon enough
don't these have an internal antenna? And presuming they do, if you can receive signals on AM/FM and the shortwave bands, it will receive SSB signals equally unless there is a problem with the product detector.
Old 06-14-2009
Yes, It has an internal antenna. But Sony recomends to install the Sony AN-LP1 ANLP1 Active Antenna. So. I wonder if it is a good one or I should put another
Paola
Old 06-14-2009
Selkirk's Avatar
Selkirk is on a distinguished road
What frequency are you trying to receive?
I would imagine that the wavelength is far to long to use an internal antennae. To calculate the wavelength, divide the frequency in megahertz into 300 (the speed of radio propagation is 300 million meters/sec). The answer will be in meters and your antennae should be electrically about 1/4 of that wavelength. Electrical length may or may not be the actual length of the antennae.
For example, it I wanted to receive something in the range of 15 megahertz, I would be dealing with a 20 meter wavelength, so I would want an antennae that is 5 meters long. That's a pretty long antennae, so the manufacturer would make it appear electrically longer by adding a coil to an antennae that is somewhat shorter than 5 meters.
That's why they are recommending an external antennae. By the time they electrically extend a small piece of internal antennae to be 5 meters, they have destroyed its sensitivity.
PS.....Look into using your back stay; that's long enough.
When you come to a "Y" in the road, take it....Yogi Berra
Old 06-14-2009
Paola
There is nothing magical about an antenna for receiving signals. The antenna must be of a resonant length only for transmitting (or alternatively use a matching network) but to receive, anything of reasonable length will ordinarily suffice - the longer, the better; the higher, the better. The device you describe is some sort of amplified antenna not dissimilar to those sold for television antennas but again, ordinarily, it isn't worth the cost (in my opinion) unless you are into weak signal shortwave listening.
Having said that, the old adage still applies - "it can't hurt"
Old 06-14-2009
Thanks for everything
And now a silly question. I am not from here, I am from Spain and I am a little confuse about the UTC here in Miami.
Could you tell me about that and tell me when do you change the time?
Thanks again
Paola
Old 06-14-2009
camaraderie's Avatar
moderate?
utc is the time in Greenwich England...London Time. I think that is the SAME tome zone for Spain.
You do need an external antenna. Like one of these:
Kaito KA33 Active Loop Antenna KA-33
Sangean ANT-60
Check my earlier post here for a bit of additional help and good luck!
http://www.sailnet.com/forums/gear-m...tml#post411287
Old 06-14-2009
NolaSafari's Avatar
Hooks Marine Custom
NolaSafari is on a distinguished road
Thanks again
Paola
UTC Should be Eastern Time Zone with Daylight Savings -4 UTC
It is best to match your receiving antenna, or trim it. Do a search. Also search long wire antenna which is what PP is referring to.
I use a screw drive antenna on my boat which was originally designed to be used as a mobile antenna on a vehicle. I transmit on several bands. Using your backstay entails installing insulators at certain points to get the correct length see the PP. Most backstay antennas are used for transmitting and will require an antenna tuner, not really necessary for receiving. SSB radios are an entire world in themselves.
Jim N5TJZ
S/V Wandering Spirit
High-Frequency Radio Basics Kathy Barron Seamanship Articles 0 10-14-2000 08:00 PM
High-Frequency Radio Basics Kathy Barron Gear and Maintenance Articles 0 10-14-2000 08:00 PM
High-Frequency Radio Basics Kathy Barron Her Sailnet Articles 0 10-14-2000 08:00 PM
Choosing and Installing an SSB Radio Sue & Larry Gear and Maintenance Articles 0 09-28-2000 08:00 PM
Choosing and Installing an SSB Radio Sue & Larry Cruising Articles 0 09-28-2000 08:00 PM
