06-17-2009
Best Looking Moderator
Originally Posted by Vasco
On my own boat I run the chain out onto the dock to mark it. I have 200 ft of chain and mark it at 15 feet, 50 feet, and 150 ft. I just put in one cable tie at each mark and also paint the chain white for a couple of feet. The 15 ft mark tells me I'm close to the anchor when weighing also when anchoring (usually in about 10 feet) I put the first mark in the water and then let the boat drift back a bit. Unless it's very crowded I usually put 100 ft in the water. I like to sleep at night.
I actually painted mine with colorcodes. The paint does wear off, so it does require some maintenance, but we found the painting easier to identify especially at night.
We used to tie the zip ties and things, but always seemed to miss them - especially if pulling into an anchorage at night.
Just a different approach.
- CD
Catalina 400 Technical Editor
Catalina 400, HN#289
Com-Pac 16
Are you trying to talk your spouse or family into cruising or sailing? Want to know what it is like, every day? Click here and enjoy: To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
