Blogs
User Name
Old 06-17-2009
sailak's Avatar
sailak sailak is offline
sailak is on a distinguished road
Anchor retrieval buoy
I don't have a windlass. Hand over hand for a 35lb Bruce and 30 feet of chain is a bit of a workout.
Any thoughts on the anchor retrieval floats? Pros/cons?
One downside I can see is the room needed to overrun the anchor and pull it to the surface -- a tight cove may not offer the room.
Dale
S/V Cirrus
Omega 36
Old 06-17-2009
sailingdog sailingdog is offline
sailingdog is just really nicesailingdog is just really nicesailingdog is just really nicesailingdog is just really nice
Why not get a chain pawl. It would allow you to deal with the 30' of chain and take the anchor's weight when you rest.
If you're new to the Sailnet Forums... please read this POST.
Old 06-17-2009
Vasco's Avatar
Vasco Vasco is offline
Warm Weather Sailor
Vasco is on a distinguished road
An anchor buoy will only cause grief. In the Bahamas it's a no no. Too many folks running around in dinks in the dark. Also in tidal waters it's not unusual to find the bouy line wrapped around your prop in the morning. The only place I might consider using one would be in certain sections of the ICW where you're anchoring in a stretch that once was forest and has a lot of stumps on the bottom. Also in crowded anchorages the boat ahead of you will many times be sitting right over your anchor.
As for hauling your hook by hand you can wrap the chain around a cleat or use a chain hook on a short line to hold it while you catch your breath.
Rick I
Toronto in summer, Bahamas in winter.
Sponsored Ad
Old 06-17-2009
capn_dave's Avatar
capn_dave capn_dave is offline
Seinor Member
capn_dave is on a distinguished road
Smile Sumthin musta got lost in the translation EH?
The anchor retrieval ball will work great!!! Anywhere even in the Bahamas. I used to do it all the time. I finally got a windless so I don't use it as much.
Here is a link to one Anchor Retrieval System.
You can make your own, isn't much to it. What is amazing is how well it works. I had never heard of it until I ran into a commercial fisherman that uses it. I thought he was crazy. Soooo When nobody was around I tried it. Holy Mackerel Andy worked like a charm.
Fair Winds
Dave
Old 06-18-2009
Craig Smith's Avatar
Craig Smith Craig Smith is offline
Anchorsmith
Craig Smith is on a distinguished road
Arrow Buoyed retrieval lines
If you think you need the ring system, why not just use a dedicated retrieval line? It is going to be much more reliable and has other benefits.
Marking where your anchor is can be beneficial in some anchorages, for other boaters who assume that a 1.5 : 1 scope is normal. Use a cheap but tough and brightly colored buoy; if folk want to run it over cos they can't see where they're going that's their issue. It also pays to mark it "not a mooring" or something similar, for certain other folk...
Pictures and more info:
www.rocna.com/kb/Buoyed_retrieval_line
Craig Smith
affiliated with Rocna Anchors
Old 06-18-2009
erps's Avatar
erps erps is offline
Puddin' head
erps will become famous soon enougherps will become famous soon enough
Could you use your main halyard winch to retrieve the portion of rode made up of line?
Ray
S.V. Nikko
1983 Fraser 41
La Conner, WA
http://www.youtube.com/watch?v=r5EWSEP-JA8
Boating for over 20 years, some of them successfully.
Old 06-18-2009
sailak's Avatar
Main halyard winch is on the cabin top but I have a couple big Genny winches that could be used.
One problem I have at present is the lack of a good anchor roller. The factory roller is a tiny little extension of the toe-rail and the roller itself has literally fallen apart and so far I've not been able to find a replacement roller (I need a narrow one - about 1 3/4").
Dale
S/V Cirrus
Omega 36
Old 07-02-2009
dave6330 dave6330 is offline
dave6330 is on a distinguished road
Fair Lead
Set a snatch block midship on port side as a fair lead - trail the anchor line to the main (same side) and have your partner tail the line into the anchor locker back up at the bow. A bit slow but it'll get the job done.
Dave
[/SIGPIC]Dave
Sailing out of Seward, Alaska
"Fight the good fight, holding on to faith and a good conscience. Some have rejected these and so have shipwrecked thier faith"
vB code is On
Protecting Re-Painted Topsides from Mooring Buoy wolfmt General Discussion (sailing related) 5 02-11-2008 12:14 PM
"Live" Buoy data maps MilfordMaWx General Discussion (sailing related) 10 02-06-2007 10:11 PM
Let’s Hear it for the Buoys Ralph Doolin Seamanship Articles 0 05-22-2003 09:00 PM
Aids to Navigation Jim Sexton Learning to Sail Articles 0 02-01-2000 08:00 PM
Aids to Navigation Jim Sexton Seamanship Articles 0 02-01-2000 08:00 PM
Page generated in 2.1061 seconds (91.47% PHP - 8.53% MySQL) with 15 queries
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.0.0 RC8
(c) Sailnet 2000-2006
