06-18-2009
Super Moderator
In the past I have used small diameter pvc pipe and fed it in from the aft end of the boom. I tie a pigtail through a hole drilled in the end of the pipe and which I fish out with a hanger. It is very cheap and stiff and flexible enough to work well. The one caviat is that you need a boom end fitting with and access area.
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Curmudgeon at Large- sailing my Farr 11.6 on the Chesapeake Bay
