How loose is your main sheet while raising the main? - Page 2 - SailNet Community
View Poll Results: How loose is your main sheet while raising the main?
I keep the main sheet tight 6 8.82%
I keep the main sheet a little slack 26 38.24%
I keep the main sheet completely released 36 52.94%
Voters: 68. You may not vote on this poll
post #11 of 34 Old 06-22-2009
Zanshin's Avatar
I singlehand and set the autopilot to head straight into the wind in wind mode, so that the boat will change heading if the wind changes. The boom is high I can't reach it and my boat has in mast furling. Nevertheless I keep the main sheet loose while pulling out the main sail.
Zanshin is offline
post #12 of 34 Old 06-22-2009
poopdeckpappy's Avatar
I completely release mine
1955 Blanchard 51 Custom ( I got a woody )
1974 Ranger 33
Friends don't let friends do stupid things alone
poopdeckpappy is offline
post #13 of 34 Old 06-22-2009
SailKing1's Avatar
I have always kept the mainsheet tight. I would most always singlehand and did not like the opportunity for the boom to fly around while getting back into the cockpit and knock me over. Even after I had run all the lines aft so I could raise the main from the cockpit I would still keep the mainsheet tight. WHen I raised the main from on deck I would let the halyard go into the cabin through the companionway and once the sails where set and the boat was on course I would wrap the halyard and stow. I guess when you singlehand you figure out wats that you are most comfortable with and fit your agility.
SailKing1 is offline
post #14 of 34 Old 06-22-2009
OK, maybe this is a stoopid question. Several responses have mentioned they keep the mainsheet tight as they don't want to take the chance of havine the boom fly around. To my understanding, this would only occur if the boat were'nt headed directly into the wind. In this instance, would a significant heel be preferable to a boom swing?
Please correct my errors as necessary...
Eric
ericread is offline
post #15 of 34 Old 06-22-2009
Apropos of Nothing
painkiller's Avatar
I keep a bit of slack in the mainsheet, after taking up the boom with the topping lift quite a bit. This allows me to hoist the main sail completely without fighting the mainsheet, and prevents the boom from moving around too much.
Same here, except the topping lift part. I get an easier hoist if nothing is pulling down on the sail.
painkiller is offline
post #16 of 34 Old 06-22-2009
SailKing1's Avatar
Eric
If the boat heels with the tiller loose it will round up. I am hooked to the mast and not going anywhere. If need i can make my way back into the ccockpit. If a wind shift happens while getting off deck and the boom swings i'm over the edge and if hit in the head knocked out.
post #17 of 34 Old 06-22-2009
T37Chef's Avatar
If you notice CD, our infamous moderator, cannot answer this question as he has never raised his sails and has no idea what you people are talking about..."main sheet, pu, thats for the master stateroom, whatever"
I for one want to know how to link my auto pilot to the wind meter, that is cool!?
Shawn
T37Chef is offline
post #18 of 34 Old 06-22-2009
Very true...
What autopilot and wind instrument do you have. If you have both Raymarine... then connect them with a Seatalk cable... and you're done.
óCpt. Mal Reynolds, Serenity (edited)
StillóDON'T READ THAT POST AGAIN.
sailingdog is offline
post #19 of 34 Old 06-22-2009
ancient mariner
captbillc's Avatar
i have a profurl in boom furling system for the fully battened main. i head into the wind with the auto pilot on, & loosen the sheet. i have a solid vang & it's hard to get the main all the way up without the sheet loose.
Liberals are people who care about others. Freethinkers are not constrained by the myths of religion.
captbillc is offline
post #20 of 34 Old 06-22-2009
Moderator
Jeff_H's Avatar
This seems to be a thread about whether we ease and reset our topping lifts every time we raise and lower the mainsail. At least on my boat, the topping lift is set so that it is loose enough to sail whenever the mainsail is hoisted, no matter how hard I haul in my mainsheet, and I never adjust it otherwise. Consequently, I have to ease my mainsheet or I can't haul my sail up. Its that simple.
That said my halyard winch is near my mainsheet so I keep the sheet tight until the mainsail is halfway or more up before releasing the sheet.
Obviously, if you ease and tighten your topping lift with each mainsail hoist, then it doesn't matter one way or the other whether you release the mainsheet when you hoist the mainsail. Except that, with the mainsheet tight, most boats will weathercock into the wind when the sails are almost up, making it easier to finish the hoist.
Jeff_H is offline
Outhaul for Loose Foot Main Quickstep192 General Discussion (sailing related) 21 06-06-2011 01:07 PM
slugs catching upon raising main remazerov Seamanship & Navigation 24 09-04-2006 08:03 PM
Adjustable Sheet Leads Brian Hancock Seamanship Articles 0 02-08-2002 08:00 PM
Reading Flow and Making Adjustments Tom Wood Learning to Sail Articles 0 09-23-1999 09:00 PM
Reading Flow and Making Adjustments Tom Wood Seamanship Articles 0 09-23-1999 09:00 PM
