How loose is your main sheet while raising the main? - Page 4 - SailNet Community
View Poll Results: How loose is your main sheet while raising the main?
I keep the main sheet tight 6 8.82%
I keep the main sheet a little slack 26 38.24%
I keep the main sheet completely released 36 52.94%
Voters: 68. You may not vote on this poll
post #31 of 34 Old 06-23-2009
SailKing1's Avatar
On my islander 26 I pulled my main up by hand and would use approx. 1 - 2 twist on the winch to bring it taught. I always keep my mainsheet tight while hoisting the main. With that said even centered and tight the boom will still sway about 1 1/2 feet.
I started this process because before I ran the lines aft I was making my way back to the cockpit after raising the main one day and a power boat came out of port causing a wake that hit the boat at the same time I stepped down of the cabin top. Boat heeled, boom swung and I almost went over. From that day on my mainsheet was always tight.
SailKing1 is offline
post #32 of 34 Old 06-23-2009
rodgerdodger's Avatar
Running Stays
I have to keep my mainsheet just loose enough to get the sail all the way up, but I have to keep it pretty tight to keep the head of the main from fouling on the running backstays
rodgerdodger is offline
post #33 of 34 Old 06-23-2009
Mermaid Hunter
SVAuspicious's Avatar
Originally Posted by jason3317 View Post
It's important to loose the mainsheet when hoisting the main to get a full hoist, plus make it easier on the crew grinding the halyard up.
In addition, you should probably slack the vang too, if it is not already.
Agreed, especially short-handed or single-handed. If the helmsman or auto-pilot can't keep the boat directly into the wind a completely slack mainsheet will allow you to get the main all the way up more quickly and the boat under sail.
If you have a solid vang this works really well. Release the vang, ease the topping lift (if you have one), and let the main sheet run free. With the boat as much into the wind as you can manage haul away. Even with a very bad back I can get the main up to within a couple of feet of the tape in half a minute or so, and grind the rest of the way up in short order. With the main up, I can return to the cockpit, get the boat on course, set the jib, set the autopilot, and return to the mast to tidy up.
If the main sheet is too tight you will be fighting the breeze pushing the main to leeward as you try to grind the sail up. Too much work.
SVAuspicious is offline
post #34 of 34 Old 06-24-2009
An Aussie Sailor
Mipcar's Avatar
I have a topping lift but still find the main runs up easier if I take a little tension off the sheet, not loose, just eased a little.
Mychael
Mipcar is offline
Outhaul for Loose Foot Main Quickstep192 General Discussion (sailing related) 21 06-06-2011 12:07 PM
slugs catching upon raising main remazerov Seamanship & Navigation 24 09-04-2006 07:03 PM
Adjustable Sheet Leads Brian Hancock Seamanship Articles 0 02-08-2002 07:00 PM
Reading Flow and Making Adjustments Tom Wood Learning to Sail Articles 0 09-23-1999 08:00 PM
Reading Flow and Making Adjustments Tom Wood Seamanship Articles 0 09-23-1999 08:00 PM
