View Poll Results: How loose is your main sheet while raising the main?
I keep the main sheet tight 6 8.96%
I keep the main sheet a little slack 26 38.81%
I keep the main sheet completely released 35 52.24%
Voters: 67. You may not vote on this poll
Old 06-22-2009
legarots is on a distinguished road
When on a boat with a diesel, and raising the main while motoring into the wind, how loose or tight is your main sheet?
Old 06-22-2009
bubb2 has a spectacular aura about bubb2 has a spectacular aura about bubb2 has a spectacular aura about
I keep the main sheet tight! I don't want the boom swinging side to side across the cockpit. Also on a boat where you raise the main at the mast, very few things can put over the rail quicker than a swinging boom.
Never Forgotten
Old 06-22-2009
jkimberly is on a distinguished road
Main Sheet
I single hand a lot. When its time to raise the main I usually release most of the tension on the sheet so that the boom will move about a foot or so then head up to the mast and haul it up. This allows for some breathing room if she wanders off of directly into the wind. I've had her start to fall off the wind (to either side) with a tight main sheet and it can get pretty interesting rather wuickly when the sheet is tight!
Old 06-22-2009
tommays's Avatar
I would say it depends on how windy it is and how good the helm person is
On the race boat there is so much stuff in the way you have to be perfect up wind to raise the main OR it will hang on something
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
Old 06-22-2009
I forgot to say I have autopilot that I set when I am raising the main. It will keep the boat dead into the wind.
Never Forgotten
Old 06-22-2009
ericread is on a distinguished road
Although you mention your auto pilot, I still think I would continue to completely release my mainsheet. Therer are times the wind tends to shift quite a bit, and the last thing I want is to raise my main with a significant wind on the beam.
Old 06-22-2009
US27inKS's Avatar
Midwest Puddle Pirate
US27inKS has a spectacular aura about US27inKS has a spectacular aura about
I leave the mainsheet loose. I have to go to the mast to raise the main, and I don't want the boat to start heeling while I'm coiling the halyard. Besides, I have my topping lift adjusted so the boom is a little low when the main is down, and slack with the main up. If I don't release the mainsheet, the sail won't go all the way up. I don't have an autopilot, so the boat never stays perfectly upwind. The main is always flogging on one side or the other when it's raised, I just head to the cockpit on the other side.
John USYacht 27 "Cora Lee"
Old 06-22-2009
cesarid's Avatar
SailGunner
cesarid is on a distinguished road
When the admiral is at the helm I have the mainsheet tight. If I am solo I would have it loose to compensate for not being able to keep the boat dead into the wind.
Old 06-22-2009
I keep a bit of slack in the mainsheet, after taking up the boom with the topping lift quite a bit. This allows me to hoist the main sail completely without fighting the mainsheet, and prevents the boom from moving around too much.
Old 06-22-2009
night0wl's Avatar
night0wl is on a distinguished road
I forget, sometimes, how much of a luxury it is to have all my sheets led aft to the cockpit and to have an in mast roller furling main. I usually put the autopilot on a heading, keep the mainsheet tight and then release the outhaul/inhaul...then just pull out to the last reef point....if thats steady then more....then if thats steady all the way.
S/V Jendai
Beneteau 343
Outhaul for Loose Foot Main Quickstep192 General Discussion (sailing related) 21 06-06-2011 12:07 PM
slugs catching upon raising main remazerov Seamanship 24 09-04-2006 07:03 PM
Adjustable Sheet Leads Brian Hancock Seamanship Articles 0 02-08-2002 07:00 PM
Reading Flow and Making Adjustments Tom Wood Learning to Sail Articles 0 09-23-1999 08:00 PM
Reading Flow and Making Adjustments Tom Wood Seamanship Articles 0 09-23-1999 08:00 PM
