Old 06-25-2009
labestia is on a distinguished road
Motor Sailing to weather
Hello:
When motor sailing to weather, does it make a difference if I have a full main out or reefed?
If so, what and when?
Can I allow the same angle of heel as if sailing w/o engine?
La Bestia
Old 06-25-2009
Delirious's Avatar
Pearson 31-2
Delirious is on a distinguished road
How close to weather? If directly into it you're better off dropping the main and jib.
If tacking into weather it will depend upon conditions. A reefed main will allow you to have a steadier motion in rough seas. In light airs keep up all your canvas. Heel it as much as you are comfortable with. The motor won't care if the boat is heeled unless it's a carbureator fuel system. Fuel injection would work inverted.
No expert myself, though. I don't do motor sailing as a rule. If there is enough wind to sail I do. If not, I fish or motor.
Charlie P.
To travel hopefully is a better thing than to arrive - R.L. Stevenson
I suspect that, if you should go to the end of the world, you would find somebody there going farther . . . - H.D. Thoreau
Old 06-26-2009
Valiente's Avatar
That's not entirely true. While fuel injection would work, a diesel at a high angle of heel with a sump would likely circulate its oil unevenly, and would, unless using a universal coupler, likely start to wear the transmission and the shaft as it went out of alignment as the weight of the engine unequally compressed the motor mounts.
In a survival situation, this isn't an issue, but running the engine while heeled isn't, to my knowledge, a great recipe for longevity.
This is why I mostly sail, or motorsail in light air, or motor directly into the weather if I have to go in that direction. The fore and aft motion is easier on the tranny than going from 40 degrees port to 40 degrees starboard.
Can't sleep? Read my countdown to voyaging blog @
Old 06-26-2009
Snboard976's Avatar
S/V Sabbatical
Snboard976 is on a distinguished road
If you are motor sailing to weather as a storm tactic the main should be reefed just as it is when you are sailing in high winds. If you are motor sailing to get to your destination more quickly keep the rpm and sail combination that will get you the closest to your hull speed.
Most of us rarely read the manual that came with our engine, but there will be a specified amount of heal that your engine will tolerate listed. That amount of heel should not be exceeded for a prolonged amount of time.
Chad Gleason
s/v Sabbatical Pearson 365 Hull #32
Old 06-26-2009
sailak's Avatar
Omega 36
sailak is on a distinguished road
With a low amount of fuel in the tank and enough heel it's possible, at least on some boats, to unport the fuel pickup. Don't ask how I learned that one.
Dale
S/V Cirrus
Omega 36
Old 06-26-2009
I'd also point out that on some boats, the engine water intake may not stay submersed when heeled, and on those boats, motor sailing flat as possible is a wise idea.
Weather Information Sources Michael Carr Seamanship Articles 0 09-16-2000 08:00 PM
The Weather Triangle Michael Carr Seamanship Articles 0 08-17-2000 08:00 PM
How to Sail with Weather Bob Rice Seamanship Articles 0 04-21-1999 08:00 PM
Weather Forecasts for Sailors Michael Carr Seamanship Articles 0 08-31-1998 08:00 PM
Gathering and Using Weather Information Michael Carr Seamanship Articles 0 03-31-1997 07:00 PM
