Old 06-27-2009
NCC320 is on a distinguished road
Topping Lift and Sail Shape
Today I went sailing and observed a Hunter 260 with his topping lift very tight so that it lifted the boom to the point that his mainsail never was anything but a flapping piece of fabric on any point of sail. I wanted to pull along side and to suggest to him to slack off so that the sail could take a proper shape, but he was with his girl/wife, so I was afraid that I would embarrass him. Later he put up his bimini and it became obvious that he had shortened the topping lift so that the boom would clear the bimini (but he was attempting to sail this way even before the bimini was raised). With the rig that he had, he will never get satisfactory sailing performance. And, probably in time, he will abandon sailing as being frustrating and unfulfilling.
If you happen to have a similar situation on your boat, take the sail to a sailmaker and get it recut so that the boom will clear your bimini without using the topping lift to hold the boom clear of the bimini. If you sometimes sail without the bimini and want the full size of the sail, then have the sailmaker to put in a flatting reef cringle/reef points on the sail....this is a relatively shallow cringle at the boom/leech end of the sail used normally to flatten the sail, but if done properly for this application, it will lift the boom also.
I'm sure that someone will disagree, but don't sail with your topping lift tight...if you do, you distort the shape of the main sail. Slack the topping lift off so that it does not distort the sail shape....the boat will sail better. Also, never sail with with boom attached to the pig tail wire on the back stay if you have one...the pig tail is to support the boom when sails are down. And if you don't have a topping lift, put one on your boat, but don't sail with it tightened....use it to keep the boom from dropping down into the cockpit when putting up sails.
Old 06-27-2009
jgeissinger is on a distinguished road
Ditto. The topping lift is there to hold the boom when the sail is NOT raised. Of course, if you are sailing with the bimini up you probably don't have any idea what your sail shape is anyway, so....
Old 06-28-2009
The only time you might want to sail with the topping lift tight is if you're in very, very light winds... and that only in very rare circumstances. Other than that, it should really be slackened enough to allow the boom's weight to load the leech properly....
Old 02-22-2011
Skipper995's Avatar
Skipper995 is on a distinguished road
NCC320, you are SO right on. I removed the topping lift from my boat as soon as I bought it. It's just another line to get in the way. It's not a sail control and if you have a solid vang (which I highly recommend) there is just no need for the topping lift.
I have to disagree with sailingdog on one issue however. In very very light conditions the main needs to be made as flat as possible to try and squeeze as much power out of the breeze as possible. In these conditions air flow has a very hard time staying attached to the sail. Detached air flow means loss of efficiency and power. A flat sail allows the breeze to maintain nearly complete flow attachment for best sailing performance.
Old 02-23-2011
... the problem is, though, that the weight of the boom will close the leech of the sail off and you'll lose that attached flow because, essentially 'the flaps are on'. The topping lift's support will allow the leech to maintain its proper shape without the force of a reasonable breeze.
Today's rigid vangs can often provide the same function.
1984 Fast/Nicholson 345
Old 02-23-2011
Skipper995's Avatar
Faster, I hear you and have a suggestion. Next time you're out in ultra light conditions try flattening the sail and give the boat time to establish a steady speed. Then without changing anything else apply your topping lift as you suggest and watch the boat speed. I guarantee it will drop as the boom lifts.
Old 02-23-2011
In very light conditions, a flat main won't generate any lift...and you won't move... also, not supporting the boom will close the leech of the sail, as Faster pointed out, which was my reasoning for supporting the boom with the topping lift...to allow the sail to have a fuller shape to help generate lift and to keep the leech open. Yes, flat sails help with attached flow, but you have to balance keeping the flow attached with sail shape to maximize lift. A flat sail generates almost no lift.
Old 02-23-2011
jackdale's Avatar
jackdale will become famous soon enough
Full sail for light air.
Flatter sail for heavier air. I will flatten a sail prior to reefing.
Compare that to airplane wings. Short Take Off and Landing planes have deeper camber, while high speed fighters have much thinner wings.
ISPA Yachtmaster Offshore Instructor Evaluator
CYA Advanced Cruising Instructor
Old 02-23-2011
Liquorice's Avatar
Liquorice is on a distinguished road
I agree with Skipper995!
Below 2 or 3 knots wind the sail needs to be flattened or you can't keep the flow attached.
sam :-)
Just because you're paranoid ...doesn't mean they're not after you!
Old 02-23-2011
I'm not arguing flat vs full...what I'm trying to say is that in real light air, the full weight of the boom alone will physically pull the clew down (gravity sucks...) and this will cause the leech to turn hard to 'windward', closing off the leech. This creates a very non uniform camber that cannot promote good attached flow - it is, as I said, like having full flaps on an airplane wing.
Whether you're of the 'flat' or 'full' mindset - you want a smooth uniform curve and a clean exit...
In light air do you crank on the leech line on the genny to induce a 'hook' in the leech??? Same thing.
Windward performance deseely General Discussion (sailing related) 21 04-01-2012 02:42 PM
Heavy weather sailing sailorfrank Learning to Sail 18 08-24-2009 01:24 PM
Traveler question sohi07 Learning to Sail 11 10-21-2006 11:47 AM
Sail Repairs at Sea Brian Hancock Gear and Maintenance Articles 0 09-22-2003 08:00 PM
Choosing the Right Headsail Dobbs Davis Racing Articles 0 01-29-2003 07:00 PM
