O'day 302 lost keel - Page 6 - SailNet Community
Blogs
  #51 (permalink)
Old 11-07-2009
Maine Sail's Avatar
The glass looks fine, not starved of resin... and the washers aren't cupped. There's also no stress cracking in the bilge or on the bottom of the keel stub that I was able to see. It was unusual to see the 5200 let go of most of the surface area without a fight...
Not uncommon for the factory workers to not clean the mold release wax from the hull...
As I understand it these boats were modified during production to address some stub/keel issues but I have no real confirmation of this and only hear-say from some owners. They were apparently also built under different companies too.
I would check the actual thickness of the keel stub.
On this boat it was not very thick.
______
-Maine Sail / CS-36T
  #52 (permalink)
Old 11-07-2009
Mainesail—
My understanding is that the keel had been removed and re-bedded by the previous owner, who had broken the fourth keel bolt, which is significantly smaller and weaker than the other three. I think the keel stub on this boat is a good deal more substantial than the one shown in your photo.
US27inKS—
I agree, taking a core sample would be a good idea, or at least dropping the keel entirely and looking in the existing bolt holes.
I also spoke with the lift operator and he clarified that the keel wasn't wobbling, at least not noticeably, but that there was a slight gap in between the keel and the keel stub. I believe the slight gap was due to the 5200 having pulled out of position due to the inadequate surface preparation. The reason I think that the boat did not leak to any major degree is that the keelbolts were keeping the 5200 under compression and it was effectively working as a gasket while the boat was in the water.
I would be very surprised to not see any stress cracks in the laminate if the keel was moving to any significant degree. It is a very heavy wing-keel casting, and has very significant forces on it when the boat is under sail or when the boat goes aground...which I believe Denby did do this past season...at least once or twice...
  #53 (permalink)
Old 11-07-2009
denby's Avatar
Location: Dead Sea, some times called Long Island Sound
denby is a jewel in the rough denby is a jewel in the rough denby is a jewel in the rough denby is a jewel in the rough
I hit a rock 2 summers ago. Never had water coming in from keel.
Dennis
O'Day 302
Be careful or i will do what the voices tell me to do
To get the most from Sailnet, follow the link in
's signature.
Hey stuffit "Get a life"
  #54 (permalink)
Old 11-08-2009
mintcakekeith is on a distinguished road
Testing in situ keel bolts with a torque wrench tells you nothing except perhaps that it is corroded in place. the only way to check keel bolts is to draw them, visualy inspect and if stainless give them a good smack with a large hammer.check lubricated bolt for correct torque on reffiting.
My First Boat...Boat Term Question... Kacper General Discussion (sailing related) 38 09-23-2008 07:52 PM
Fixed or swing keel, which is better? TimG2 General Discussion (sailing related) 15 03-20-2008 05:36 PM
reducing keel/adding fin? abacosol Gear & Maintenance 9 07-01-2007 10:32 PM
Keel Bolt Repairs Don Casey Gear and Maintenance Articles 0 11-10-2003 08:00 PM
Keel Bolt Concerns Don Casey Gear and Maintenance Articles 0 10-12-2003 09:00 PM
SEO by vBSEO 3.6.0
(c) Sailnet 2000-2006
