Old 06-29-2009
davidpm's Avatar
davidpm is on a distinguished road
dinghy options
My friend has a Catalina 30 and is thinking about getting a dinghy. Towing one is possible of course but a pain. He will never spring for davits and it seems like a c30 is a little small for that solution.
The for-deck is the most likely place of course but it seems it will be a little tight for a normal size dinghy.
I have a sit-a-top kayak we have used in the past but, but that gets a little wet and only takes two people. I'm wondering what else people have used successfully.
Old 06-29-2009
RXBOT is on a distinguished road
Sportyak
Tell your freind to check out the sportyak and the new 245 model by BIC. I think the sportyak is 45 pounds.
Old 06-29-2009
An 8foot zodiac would fit quite nicely on the foredeck of a C30 and will handle 4 persons for trips ashore.
They can often be found on Craigslist and similar buy-sell listings for reasonable money.
1984 Fast/Nicholson 345
Old 06-29-2009
lshick is on a distinguished road
Send a message via Skype™ to lshick
Nesting dinghy
Or consider a nesting dinghy: it comes apart in two halves (fore/aft) so the fore part nests inside the aft part. There are plans on the internet. Or, with a little careful planning, you could take a stock dink, saw it in half, make the thwarts removeable/replaceable, a little thinking about how you bolt it back together, and there you are.
Larry Shick
V42-148 "Moira"
Old 06-30-2009
PalmettoSailor will become famous soon enough
I am a bit leery of towing since you never know when you might get caught out in less than benign conditions. My dingy flipped while being towed last year and I lost my seat bag with the pump and I don't remember what else plus it stripped the number plates with the registration numbers. At least I had the sense to have the outboard on the pulpit rail and the oars in the lazerette or they'd be gone too.
This year I've tried the dink on the foredeck of my Catalina 36 and hate it. I'd have to put down padeyes to adequately secure it without creating a trip hazard, and its a magnet for the sheets when tacking. I'm back to towing but if there is any threat of weather I'll deflate the thing, roll it up and store it at the base of the mast. That way it'll be out of the area where you need to move on deck and won't catch the sheets.
PalmettoSailor (formerly midlifesailor)
s/v Palmetto Moon
1991 Catalina 36
Old 06-30-2009
deniseO30's Avatar
Lies about her age
I've towed a dink quite a bit and have also stored it on the foredeck. I'd rather tow it. It's not a pain at all IMHO sometimes it's a concern when going in reverse for docking, other then that I't works out ok for me.
Old 06-30-2009
eryka is on a distinguished road
Towing our 10-foot RIB can cost half a knot to a knot of boat speed, even with the engine on the rail. If we're going any distance at all we partially deflate it and put it on the foredeck. The time it takes to put up & down is more than made up for with the time we save sailing faster.
Old 06-30-2009
davidpm's Avatar
Originally Posted by eryka View Post
Towing our 10-foot RIB can cost half a knot to a knot of boat speed, even with the engine on the rail. If we're going any distance at all we partially deflate it and put it on the fore-deck. The time it takes to put up & down is more than made up for with the time we save sailing faster.
What is the inflation, deflation process like. Never done it. What do you use to inflate, how long does it take etc.
Old 06-30-2009
cesarid's Avatar
SailGunner
cesarid is on a distinguished road
Isn't a 10' RIB pretty heavy? How do you lift it on the deck?
Old 06-30-2009
It takes about 15 minutes or so using a foot pump to pump up our 8' Zodiac. Its not too bad at all, but you wouldn't want to do it every day unless you had to.
s/v Palmetto Moon
1991 Catalina 36
Choosing a Dinghy Sue & Larry Gear and Maintenance Articles 0 10-11-2004 08:00 PM
Choosing a Dinghy Sue & Larry Gear and Maintenance Articles 0 10-09-1998 08:00 PM
