07-08-2009
I would use Butyl tape instead... IMHO, silicone has very little place on a boat, outside of bedding deadlights and covering the ends of cotter pins.
Originally Posted by weephee
Can someone tell me if it's OK to use GE silicone to seal the mast plate to the fiberglass. I'm not sure what it is called but it's a cast aluminum piece that the mast sits on when installed. The plate on my boat is secured with 4 1 1/2 inch lag bolts. I want to make sure no moisture leaks under it. Thanks
