Old 07-14-2009
caliman is on a distinguished road
Atomic 4 - RPM Drops, Then Comes Back Up
Hello -
I have a curious issue with my Atomic 4 on my Ericson 27.
Periodically as I leave the channel to go sailing I will experience a drop of about 20% in RPM/power for a couple minutes or so, then it goes back to where it was. When it drops, I notice the AMP meter goes way up to about 5 from just above 0.
When the RPM/power goes back to where it was, the AMP meter goes back down to just above zero.
This happens more often when first using the motor rather than later. Although it does happen when hot too.
What I have done (within the last two years):
- New ignition coil, new points, cap, spark plugs, spark plug cables
- Set timing per manual
- New fuel line
- New fuel filter (just changed over the winter - old one was not dirty)
- New muffler and exhaust pipes
I recently tested the alternator and it passed just fine bringing in 15v at slightly above idle throttle. It is the original alternator though.
The motor otherwise works well, idles well and starts easily.
What causes this drop in power? Is this normal or can I fix it?
Thanks in advance!
matt
Old 07-14-2009
Boasun's Avatar
Boasun will become famous soon enough Boasun will become famous soon enough
Have you checked your voltage regulator?? And the other compotents of your electrical system? A heavy drain on the altenator will pull your engine RPMs down.
1600 Ton Master, 2nd Mate Unlimited Tonnage
Maritime Instructor
S/V Rapture
Old 07-14-2009
Good question - I have not checked the regulator - I am not sure where that is actually.
Old 07-14-2009
Well-wisher
pschoonveld is on a distinguished road
I agree. It sounds like the alternator is kicking in and dragging down.
Most A4s have internal regulators in the alternator. Your best bet is to pull it and find a local generator shop. An automotive parts store can test it, but most likely won't understand how it actually works and what to look for in low rev, high output alternators. They frequently deal in funky alternators like those for the A4 and deep cycle batteries.
If it's more than 10 years old and has the subsequent hours on it, you might just be best off getting it rebuilt regardless. Many small shops can put in higher performance bits and pieces to drive up the power, which is usually worth it.
Incidentally, I have an E27 with an A4 and just got done (hopefully) chasing out my charging issues. I found my local generator shop more useful and significantly less expensive that swapping parts with Moyer. Having said that, Moyer Marine is the place to go when you need A4 wisdom or parts.
Old 07-15-2009
SEMIJim's Avatar
Last Grumpy Old Sailor
SEMIJim will become famous soon enough SEMIJim will become famous soon enough
You're not running a refridgerator or air-conditioner, mayhaps?
Jim
Old 07-15-2009
Thank you.
I have had thought my alternator has needed attention for some time. I was surprised it puts out a decent charge from what my meter says and that gives me pause but it still is suspect to me. Simply, it is dirty as hell. Perhaps this affects it, perhaps not. I am not sure? Anyway, I always thought a modern alternator and regulator would be a nice upgrade. At the same time, I see what you are saying about just having it rebuilt. That would certainly help I bet. Check out these pics (sorry - nite time flash light plus cabin lights!
Old 07-15-2009
Jim
No I am not Jim.
Old 07-15-2009
imagine2frolic's Avatar
imagine2frolic is on a distinguished road
Have you tried feathering the choke? If that keeps the rpm's up. Then the carb may need cleaning.......i2f
20 MPH ain't fast unless, you do it in a 1000sq 3/2 house on 10foot waves
BORROWED, No single one of us is as smart as all of us!
Old 07-15-2009
I have not done this. I have never cleaned the carb. I suspect it needs it too. I am soaking up the courage to do so.
Old 07-04-2010
A year later - I owe a huge belated thankyou to Boasun - it was the regulator. Cost me only $50 for a new regulator installed - runs flawlessly now. Big thanks!!
Back From 9 Day Cruise through LI Sound to Newport nk235 Cruising & Liveaboard Forum 8 09-01-2008 10:36 AM
diesel troubleshooting - low rpm rperret Gear & Maintenance 16 08-26-2008 06:18 AM
Chesapeake watermen fear blue crab not coming back Freesail99 General Discussion (sailing related) 20 07-17-2008 11:18 AM
Electrical Problem - Newbie Not Sure Where to Start wolfmt Gear & Maintenance 32 07-14-2008 09:17 AM
St. Maartin, St. Barts & Anguilla bbayer4230 Chartering 2 04-23-2006 06:04 PM
