07-20-2009
Originally Posted by pegasus1457
I sent an email query to Balmar asking about adding an external regulator to my existing Motorola alternator. [I believe the Leece-Neville alternator is equivalent to the Motorola, which is no longer manufactured.] In their reply, Balmar made a comment which is relevant here: they pointed out that automotive alternators are designed to give a specific output at 2- to 3- times the RPM we cruise at in our sailboats, so they will never give the kind of performance we expect, trying to charge the house battery running the engine an hour or so each day.
The Motorola is a 55 amp unit & the Leece-Neville is 90 amps in a marine, not autoversion. They are not equivalent. I believe it will perform every bit as well as a comparable Balmar that costs 4X as much. The L-N is a small frame unit so it is much easier to install. The Balmar will likely need a new bracket & perhaps a new crankshaft pulley, but the L-N won't. Maine Sail has a nice write up about the installation which I used as a reference when I did the job.
I didn't realize they make the alternators for Balmar, though.
Keith
Rocinante
1983 Ericson 33
Channel Islands, California
