-   -   Beach Hauling Options (http://www.sailnet.com/forums/general-discussion-sailing-related/56361-beach-hauling-options.html)
davidpm 07-19-2009 11:50 PM
I have access to a beach where I keep a Hobie 18 that weighs about 400 lbs. With beach wheels two people can usually get it off the beach with out too much trouble. Some times the beach is a little steep and it is harder but doable.
I may be able to get a Rebel 16' but this boat weighs 700 lbs.
I doubt if I could move it off the beach by hand even if I made wheels. It comes with a trailor but I can't get the trailor in to this beach.
There are some heavy duty poles at the top of the beach so I was thinking of some kind of block and tackle system but that sounds slow, we are talking about hauling about 250'. Also getting it back down to the water is a problem.
Anyone solve this problem. Probably should just forget about the Rebel but thought I would ask in case I'm missing something.
davidpm 07-23-2009 09:54 AM
I ended up buying a International 420. Two people can haul it up the beach but not one.
I measured the distance and it is only 120'. I'll bet a 4 or 5 to one tackle setup would work. I'm looking at granger etc to find some suitable blocks. I don't think I need to spend $200 each on sailboat rigging quality.
If anyone has a lead on a couple of double wheel blocks, one with a becket for line in the 3/8" or so size I would like to hear it.
davidpm 07-28-2009 10:38 PM
I borrowed a 4 to one tackle setup and gave it a try. It worked pretty well. I think I'll makup my own 5 or 6 to one setup and I should be able to haul it a hundred feet with some sweat.
Now to find some blocks that will do the job.
hellosailor 07-29-2009 11:59 AM
120 feet with a 5:1 tackle and you'll still need to haul in 600 feet of line. Not to mention--haul the spool of line.
Grainger, Mcmaster, Agway, any farm or industrial supplier...although I have to wonder how that line is going to like getting sand in it all the time, too.
nickmerc 07-29-2009 01:07 PM
I had a similar problem with my Hobie 18. 2 could easily move it on beach wheels, one... not so much. Especially up the grade. So, I made a portable beach winch with an ATV electric winch (with remote), a battery, and a 4x4 post that I anchored at the top of the beach. It had about 100' feet of cable so I sometimes had to relocate the winch if the distance was less than 100'. Worked like a charm.
________
CollegeBrunete
davidpm 07-29-2009 03:56 PM
I found this suppler or line: Polyester composite double braid prices and specs
I'm not sure how I tell if it is the same quality as Yacht braid, not even sure I care. (Sand ?)
chef2sail 07-29-2009 09:34 PM
I lived in Ocean City NJ for 18 years on the beach and had a Hobie infront of the house on one of the designated "catamaran beaches". I very often sigle handed and developed an efficient way of bringing the boat up from or down to the water by getting the beach wheels under the pontoons and using the jib sail to catch the wind giving me extra power to power up or down the beach.
Usually at the end of our sails in the afternoon there was pretty good wind and many times singlehanding I would not take the main down until after I had it help "power" the boat up the slope of the beach. Your sails can work for you not just on the water, but on the land also.
Dave
davidpm 07-31-2009 12:42 AM
I just ordered this winch
Mile Marker Tough Series ATV/UTV Winches
The specs say that it will pull 500 lbs at 16 feet per minute and use 62 amps. I need to pull probably 300 lbs for 100 feet so my load will be for about 7 minutes.
I have the following portable battery
Booster Pac ES2500KE 12 Volt Jump Starter Booster Pac ES2500
900 peak amps.
17 amp hour battery.
I know some of you are good with figuring out this battery stuff.
Will this battery work and how did you do the calculations?
camaraderie 07-31-2009 12:26 PM
David...well that is simply not going to work.
1. Your battery pack is not designed for a deep cycle load...just a few seconds at a time. The 250 CCA (cold cranking amps) that your pack is rated for means it can deliver 250 amps for 30 seconds before being dead flat (10.5 volts).
2. Any wet cell battery BANK that would be able to handle this job should be sized at at least 300ah to handle the 62 amp load (MAXIMUM current should not exceed 20% of battery capacity...62amps is 20% of 310ah's). By going to an AGM battery you could cut in half the size of the bank quite comfortably and if you want to go further a single Odyssey group31 battery could handle this load since it is able to handle current up to its' rated ah's. The price though is quite a bit higher ($300 or so) but it is a single battery and can be recharged at high rates and discharged quite deeply (80%) and still provide good life cycles. The weight is 77 lbs.
Amazon.com: Odyssey 31-PC2150T Heavy Duty Commercial Battery: Automotive
Your actual amp hour usage per hauling will be 7/60ths of the 62amp draw per hour...or about 7 amp hours per haul...so the Odyssey would allow you to do around 10 hauls on a single full charge before needing to be carried back for a re-charge from a THREE STAGE battery charger.
There may be other approaches to powering this winch such as running electric down to a ACtoDC power supply or buying an old jeep and running the engine to power the winch...:D... but the Odyssey seems to me to be your best shot at something working reliably. Hope this helps!
EDIT...the Sears Platinum Marine Battery group 31 is the SAME battery as the Odyssey 31 and will save you $50-60 bucks.
davidpm 07-31-2009 08:20 PM
Thanks, I suspected as much. What I'm hoping is that I'll end up only having to do maybe 50' and my load may be much lower maybe 200 lbs.
It will be easy to find out but it looks like I'll have to buy real battery.
Does sears have the appropiate charger? What would work well with this battery?
The weight is a problem to haul to the beach and back.
If the Sears battery is the same as the Odesey it must be AGM? How did you figure that out, the Sears website give very little info that I could find?
I only need one maybe two hauls between charges.
I thought AGM's could handle faster discharge rates or is that only faster charge rate?
From Sears site:
The PM-1 Platinum Marine Battery from DieHard features 205 minutes of reserve capacity and 1150 cold cranking amps. Provides power for RVs, trolling motors, marine accessories and starting needs. The combination stud/post terminal design allows for multiple connections. Its corrosion-resistant high quality tin-coated brass terminals provide reliable starting power in all weather conditions. Its rugged, military-grade construction features robust casing for increased compression and offers superior vibration resistance.
Does this mean 205 minutes to dead at 25 amps.
100 minutes to half charge at 25 amps
40 minutes at 62 amps
40 / 7 minutes per haul is about 6 hauls
Is that the calculation
