Outboard Size for 23ft sailboat? - Page 3 - SailNet Community
Blogs
  #21 (permalink)
Old 07-25-2009
roline's Avatar
Cal 9.2 SilverSwan
roline is on a distinguished road
I hava a 95 Johnson 3.3 hp 2 stroke( painted black and sold at mercury also) 28lbs internal tank on a Santana525, 2400lbs. It will cruise at 5.3 knots wide open. going through the calculations, to go hull speed, I would need 5hp. There are advantages / disadvantages to an internal tank, convienient until it runs out, smaller volume than an external tank. Just shy of 1/2 gallon, I can get 45 minutes on a full tank. My priority was weight, wanting to keep under 30lbs if possible
Cal 9.2 #19 SilverSwan
  #22 (permalink)
Old 07-25-2009
dabnis is on a distinguished road
Snider,
I had a Coronado 25 which weighed about 4,000 lbs, IIRC, sailed out of Sausalito on San Francisco Bay for many years. Started out with a 6hp Evinrude 2 stroke which was marginal for beating through the steep rough chop and fast currents both inside and outside the bay. Went to a 15 hp, which was the same weight as the 9.9, and it really did the job. The Coronado had a well so had no problem with the long shaft motor coming out of the water. I would suggest you get the strongest motor with the longest shaft you can fit on the transom. Electric start with a charging feature would complete the package.
FWIW, Dabnis
  #23 (permalink)
Old 07-25-2009
TohatsuGuru's Avatar
Misanthrope
TohatsuGuru is on a distinguished road
The 6 hp 25" comes with the pig prop now directly from the factory.
Elvin
Solution One Maritime
  #24 (permalink)
Old 07-26-2009
retclt's Avatar
Roadkillibus Texanis
retclt will become famous soon enough retclt will become famous soon enough
Most agree on one thing . . . 25" for sure. I've seen Charleston Harbor get pretty rolly . . . especially where the Cooper comes out. Tohatsu is a good motor but wouldn't want to be limited to a half hour of fuel. Get and external and explore a little more of the area.
Bob T
"I cannot not sail" - E. B. White
  #25 (permalink)
Old 07-26-2009
snider's Avatar
snider is on a distinguished road
Doesn't anyone sail!!
I do my exploring under sail! Ha Ha. Seriously I really sail all the time. I hope Thats what I enjoy most, working up into tight places under sail alone. I use to not have the option of a motoring and I hope I don't motor more just because I have it. Motoring takes a lot of fun out of it for me. Sure I've had to go to alternate anchorages and ran aground a few times but it's the challenge I like. I'll Probably carry an extrnal tank if I'm going to be overnighting or if I have to work the next day, but I really just need the motor as a back-up and if I have to get back and can't tack against the current. My slip is really easy to get into and out of, I could easily sail into it. It's not a T-head, I'm on the inside of all the T-heads on a long dock.
I;'m not discounting the fact that one day I may be in a real slip, thats one reason I want the motor. Docking with a crosswind and a ripping current can be a pain.
So far I think I'm leaning toward the 25" 6hp internal tank model that's about to come out. I appreciate the input. Brandon
Brandon
Charleston SC
  #26 (permalink)
Old 07-27-2009
Misanthrope
Run time on the 4 hp with the integral tank is 45 minutes at WOT and about 2 hours at 1/4 throttle.
Elvin
  #27 (permalink)
Old 07-27-2009
Misanthrope
Quick update on the integral 6....Not going to be released until at least January, probably even later. Not sure why. If I can find out I'll post the result.
Elvin
  #28 (permalink)
Old 07-27-2009
casioqv's Avatar
1974 Catalina 22
casioqv is on a distinguished road
On my Catalina 22 I have a Motor Guide 82lb thrust 24v electric trolling motor along with 2 115aH batteries. It moves the boat at about 3.5 knots, and will run almost all day long (haven't ran it empty yet).
I love that it's totally silent, the motor is light weight, no danger or cost of gasoline, and the fuel (batteries) can be located near the keel as extra ballast, which improves sailing performance unlike a huge motor and fuel tank hanging off the stern.
For me, the motor is just a backup and is used for docking and loading onto the trailer. People sailed all around the world before motors were invented, and they're not a necessary item on a sailboat IMO.
  #29 (permalink)
Old 07-28-2009
snider's Avatar
Cool Yea!!!
FINALLY Someone who understands!
Brandon
Charleston SC
  #30 (permalink)
Old 07-28-2009
snider's Avatar
Hmph!!
Well that stinks!! Wish I could find a 2 stroke around 3.5-5hp. Something under 35lbs would be sweet!!! I got the 9.9 Nissan running. Just needed some fresh fuel. That thing is heavy!! Right were you don't want extra weight. In the ends of the boat.
Brandon
Charleston SC
Coast Guard search for sailboat, crew of 4 continues - Virginian Pilot NewsReader News Feeds 0 05-09-2007 01:15 PM
Caring for the Cruising Outboard Doreen Gounard Gear and Maintenance Articles 0 04-22-2003 09:00 PM
Size Matters Don Casey Buying a Boat Articles 0 04-05-2002 08:00 PM
Minimum sailboat size to get two seperate sleeping quarters? duffer1960 General Discussion (sailing related) 9 08-02-2001 01:14 PM
Minimum sailboat size to get two seperate sleeping quarters? duffer1960 Boat Review and Purchase Forum 8 03-26-2001 07:44 PM
SEO by vBSEO 3.6.0
(c) Sailnet 2000-2006
