07-29-2009
I get it. On my Oday 23, the fuel tank locker is under a cockpit seat at the rear of the starboard side. It is a completely separate unit, and is not vented into the bilge or cabin (like some Catalina 22's). In fact, the only vent for the fuel tank locker is the exit hole for the fuel line (which is on the inboard side of the cockpit).
The locker is sized perfectly for one of the old-style steel 6 gallon fuel tanks. When I bought my new engine (Nissan 8 hp two stroke, long shaft electric start) in 2002, it came with a poly three gallon tank and fuel line. Rather than wrestle with the fittings to put the Nissan fittings on my old fuel line (or put the Johnson fittings on the new fuel line), I just swapped out the old tank and line completely (the vent and fuel gauage were busted anyway). I thought that at some point I would buy a new 6 gallon tank, but the steel tanks are ridiculously expensive, and the new poly tanks look like they will be about a half inch too big to fit in the locker. I haven't gotten around to seeing if a new 6 gallon tank will fit; I've been making due with the three gallon tank. Its not a major pain, but I find the tank to be too small. I have to fill it about three times a season, as opposed to the 6 gallon tank, which I sometimes could make last all summer, but at worst only needed to be filled twice.
How big is the internal fuel tank on the outboard you are considering?
