08-08-2009
Drill a hole at each end of the crack to stop its spreading. Then seal that crack with similar material that the tank is made of.
Some tank skins crack from flexing and you may want to re-enforce the top in order to reduce that flexing.
1600 Ton Master, 2nd Mate Unlimited Tonnage
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Maritime Instructor To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
S/V Rapture
