08-10-2009
Max Weight Capacity
I am currently retro-fitting a Halman 20 for offshore work and are trying to determine a "rule-of-thumb" formula for establishing max weight capacity before the craft rides below her factory lines. I haven't had any luck finding such information online, and am hoping someone here can help. Her specs are: LOA 20', LOW 16.5', Beam 8', Draft 3', Weight 2500 lbs, Ballast 1000 lbs. The Halmans are sister ships of the Nordica 20's. By using the old (Length X Width / 15) X 150 = 1600 lbs, seems a little light... And given the the estimated sum of upgrades + stores, if 1600 lbs. is to be adhered to, then careful consideration need be taken. Any help would be appreciated
