Old 08-11-2009
montenido's Avatar
montenido is on a distinguished road
Anchor Chain Size question
Hi all, I have a question about the diameter of anchor chain. I just went on an overnight trip with my sons, and just before departing I switched my new (and very large, 1/2" maybe?) stern anchor chain with my smaller and rusting bow anchor chain. Once at our anchorage, I found that the new and larger chain barely fit through my bow roller, and was super heavy to deploy and retrieve. I would like to replace the bow anchor chain with something a bit lighter, but I don't want to give up strength. My C30 weighs about 12,000# and my anchor is a 35# bruce. I don't have a windlass (yet) but I sure wanted one last week. What size chain should I get? I am thinking of a length of 45' to go with my 250' of rode.
Thanks in advance, Bill
Odyssey, '79 CSY 44 Cutter
Channel Islands, CA
"There is no unhappiness like the misery of sighting land (and work) again after a cheerful, careless voyage."
Mark Twain
Old 08-11-2009
TejasSailer is on a distinguished road
I have a handy book called "The Boat Data Book" by Ian Nicolson that I frequently refer to. Going on the high side, for a 30-36 ft boat weighing 8-12 tons, 240' of 5/8" line plus 24' of 3/8" chain is recommended. I've also heard of a rule of thumb of 1' of chain for 1' ft of boat. Our boat is 36' and we went with 40' of chain. We have a windlass and acquired chain the conformed to the specifications for the windlass.
Old 08-11-2009
josrulz's Avatar
Unpaid Intern
josrulz is on a distinguished road
It also depends on what type of chain. HT is much stronger than PC or BBB for the same size. So often you can "downsize" on the chain and still get the desired strength by moving up to HT. This saves significant weight (if you are looking to). Makes it easier if you don't have a windlass (we don't).
Honestly, if I was buying rode/chain for a Catalina 30, I'd go with 1/4" HT and 1/2" rode. Minimum 30' of chain, nothing wrong with more other than more weight. I probably wouldn't go bigger simply because I'd be looking to keep weight reasonable with no windlass. I'd use this for my every day anchor, then have a larger chain/rode/anchor combo for storm situations, if needed.
1984 Sabre 34 Mk I
Old 08-15-2009
weephee is on a distinguished road
Anchor Chain Size Question
What about stainless steel anchor chain. Is is acceptable and if so should I be buying a particular grade. It would be nice to avoid rust all over the bow of my 27 foot ship. Thanks
Old 08-15-2009
Barking Dog
KindOfBlue is on a distinguished road
Stainless is not a good choice for anchor chain.
Craig
Old 08-15-2009
I'm surprised by that. Can you tell me whyI should avoid stainless steel chain for my anchor
Old 08-15-2009
Barking Dog
Stainless really likes oxygen. It will eventually corrode if you use it as anchor chain. Being bunched up in a damp anchor locker along with wet nylon rode, etc is not good, when there are better choices.
I am almost certain that the welds in stainless chain are more brittle and will fail faster than galvinized.
My research suggests using G40 HT chain. I think that G40 and G4 are the same.
Craig
Old 08-15-2009
montenido's Avatar
Edit
Hi all, thanks for the input. While at the boat the other day I looked at my Bruce anchor and it is 10Kg (22 lbs) not 35lbs! That means that my chain is HEAVY! I am going to go with 5/16 HT chain after reading the advice here and elsewhere. The 22 lb Bruce is good for a 35' boat so my 30' should be fine.
Thanks again for the great input.
Cheers, Bill
Channel Islands, CA
Mark Twain
Old 08-16-2009
Craig Smith's Avatar
Anchorsmith
Craig Smith is on a distinguished road
Arrow
Craig Smith
Sailnet Disclosure: Craig is the son of the designer of Rocna and has a financial interest in its success.
Old 08-17-2009
cabron99 is on a distinguished road
Rode & windlass
Bill, read the Q's & A's in your thread. I have an '87 C30 in Ventura Harbor and just installed a windlass, 300 lf 8-plait, and 30 lf 5/16chain. Am very happy with it. Will be replacing the anchor soon. If you are considering installing a windlass, you should look at the job done on my boat. No pix yet. The fellow who performed this extremely professional job is local and reasonable. Might have to wait for him, but worth it. Let me know.
Pat
Keel/ballast Question?? Plus Extra Credit Question ;) stephenronning General Discussion (sailing related) 2 03-20-2009 07:25 AM
Another 12v power question TonyInNewportOregon Living Aboard 3 02-17-2009 10:04 AM
Motor: DIY or Pay up; that is the question canoeman256 General Discussion (sailing related) 11 10-11-2008 05:16 PM
Ladder question mcain Gear & Maintenance 14 08-03-2007 10:28 PM
self tailing winches but what size saurav16 Gear & Maintenance 24 07-11-2007 09:06 PM
