what's with the Bucc18 - Page 3 - SailNet Community
post #21 of 29 Old 08-21-2009 Thread Starter
The Brinlae Rose Lives
Roses most certainly do have thorns. I think its a classy name for a classy boat. Last night I made myself a boom vang. Funny you should mention the CB issue, I was having just that problem. The thing is ugly, but it works. My jib sheets are on the inside of the shrouds, and I'm not using the tracks at this point. I ran them through chrome guides along the rail to a static block about a foot in front of the old track. This seemed to be the most common way to do it for a cruising Bucc (riiiiiight...) judging from the research I did. It also presented as the least expensive option, as the rigs for the tracks were missing entirely. I actually have her completely rigged in my backyard right now. I need the practice stepping the mast and getting set up, so I do it ALONE in my driveway every couple days. That mast is not fun to set up by my onesies, but what can I do when no one comes over to help? Actually, once the damnable thing is vertical, its not too bad. I saw a rig where someone cut the mast off at the bottom had hinged it. Making it possible to step the mast in like, 10 seconds or something. I may have that done later.
Blessings
Steven
stevegmusic is offline
post #22 of 29 Old 08-21-2009
baDumbumbum
bobmcgov's Avatar
Most Buccs these days have the mast on a hinged tabernacle as in the photos below. It's a medium-complex job -- Harry Sindle may still have kits -- but it makes stepping the heavy mast MUCH easier than wrestling it over the centerboard. I use the spi halyard clipped to the bow eye to hold the mast upright while I run forward and attach the jib/forestay. Then I leave it in place, lightly taut, as backup in case the forestay breaks. Spi halyard attaches to the port side of the CB box; pole topping lift to starboard. There is no foreguy or pole downhaul -- that's what the spinnaker twing does.
Magic box tensions the jib halyard; older Buccs used a Hyfield lever under the deck, in the cuddy. Either one is fine. I just birdcaged my wire halyard for the last bloody time today -- Spectra cordage, here we come.
ETA: Here's a source for parts; scroll down & you'll find Harry's contact info.
Buccaneer18, Grainnia
SJ21, Diarmuid
Albin Ballad 30, Fionn
bobmcgov is offline
post #23 of 29 Old 08-22-2009 Thread Starter
new host of issues
Well, stepping the mast is the least of my worries at this point. We took her out for the first time this morning, and came up with a whole laundry list of issues. First, does anything hold down the rudder and centerboard? They both were just floating up to the up position, also we were taking on water something wicked through the scuppers. To top it all off, there was absolutely no wind at all.
We'll try again sometime, later on in the day would most likely be better for havi9ng some kind of breeze to push us along.
post #24 of 29 Old 08-23-2009
baDumbumbum
bobmcgov's Avatar
Centerboard holddown: some use bungees, I find it stays down by itself above a beam reach, you want it up downwind. Bigger problem for us is the CB rattling down when running DDW. Hence the red T-handle in the pics; it loops over a hook on the bulkhead.
Rudder holddown: typically rigged with a looped cord, one side pulls blade up, one pulls & holds it down. One or two cleats on the tiller to keep it there. Alternatively, tighten the axle bolt. Don't sail w/ the rudder the least bit up; it will steer like a truck and possibly tear the transom off.
Bailers. Oh yeah. Recall the warning about leaky bailers in my first post? Those are they. May just need wiping and lots of Vaseline on the bottom plastic bits. Some people manage to replace the O rings. Make sure the tubes are clear of seaweed, rocks or other debris; pull the black collars all the way up, hard; then finish with a 1/4 twist clockwise. They'll probably still leak, but they should leak slower.
Glad you got out! And remember, if you can sail 1 hour for every 3 hours of boat work, you are doing fine. (True for all boats.)
SJ21, Diarmuid
bobmcgov is offline
post #25 of 29 Old 01-19-2010 Thread Starter
So the wind is starting in in Texas, and the weather is getting warmer. I'll be on the water soon. Should be a good time.
post #26 of 29 Old 05-03-2010
Interested in racing your Buccaneer18? Denver Sailing Association is hosting their annual Hornblower Regatta May 15-16 at Cherry Creek Lake in Denver. Please contact me David Spira 3034788377 dspira(at)kewrealty.com or Jim Daus godausgo(at)yahoo.com if you are interested or if you want more information about Buccaneer sailing in the Rocky Mountain Region.
Buccaneer18.org groups.yahoo.com/group/Bucc18_fleet30
elusive43 is offline
post #27 of 29 Old 05-03-2010
correction
the rocky mountain buccaneer forum is:
groups.yahoo.com/group/Bucc18_fleet_30
post #28 of 29 Old 05-03-2010 Thread Starter
Still cleaning out muck from the boat, I don't think I'll be racing any time soon
thanks though
post #29 of 29 Old 05-04-2010
Glad you are enjoying your Bucc!
