Water in the bilge - Page 3 - SailNet Community
post #21 of 26 Old 08-26-2009 Thread Starter
Clever. I like that.
Definately not a leak from the mast, portlights or hatches. Hasn't rained here in weeks, and the boat is otherwise very dry. Believe me, when I first got her in the spring I spent a lot of time in the cabin with a flashlight while it was raining just looking for leaks. Thats why this has me worked up. Water level in the bilge was just fine this morning.
In the Springs
Gardiners Bay, NY
1986 O'Day 31
inthesprings is offline
post #22 of 26 Old 08-26-2009
timebandit's Avatar
Rule #1
The last thing you mucked with is the first thing to screw up.
Rick
Mac 25
Copernicus
Southern California
I am not a prejudice racist sexist bigot. I just hate stupid people.
timebandit is offline
post #23 of 26 Old 09-23-2009 Thread Starter
Eureka!
So I found out where the water was getting into the bilge from. That would be the quarter sized hole in the hull near the bilge discharge where the fish finder used to live. There was a plastic cover (with a smaller hole in it) covering the big hole, and I'm positive the water was getting in there. I dont know how I overlooked that. I guess the previous owner had a fish finder that he took with him. Why anyone would cut such a big hole for a cord to pass through, I dont know, but at least the fix is easy enough. Im going to fill the hole with marine tex and call it good. Unless you all think I should fill with epoxy and reinforce with cloth.
In the Springs
Gardiners Bay, NY
1986 O'Day 31
post #24 of 26 Old 09-23-2009
DropTop's Avatar
Originally Posted by KismetP362 View Post
I installed a 12VDC counter in line with the bildge pump/float switch. This way, when I come back to the boat after a week away, i can see the exact amount of times it came on. I reset it when I leave for a long period and I write down my findings in the Log whenever it's abnormal. So far so good. It cost me about $14.00 at H.R. DISTRIBUTORS, Inc..
Can you give a direct link to the product? their website search isn't that good...
Four Points - 1990 Hunter 27'
DropTop is offline
post #25 of 26 Old 09-24-2009
hole repair
If you have a hole the size of a quarter in your hull, you shouldn't fix it with marine tex. You must grind around the hole, creating a taper and patch it with layers of cloth and epoxy. The details are in books on fiberglass repair, or, if you don't want to do it yourself, its not too expensive to have it done by a professional.
fordo is offline
post #26 of 26 Old 09-24-2009
midnightsailor's Avatar
In the springs,
You must be close by me, I assume by your moniker that you are in the springs, E hampton? I am over in greenport, sail out of Sterling Harbor. I am often over your way, will be in SHelter Island today. I would be glad to come by and get together with you and give you some help with fixing that hole. Until you get it fixed (and I would not wait long to do that) it would be good to temporarily plug it with a tapered soft wood plug, or at least fill it with some silicon(somthing easy to remove)or even duck tape, but getit covered up, a hole that close to the waterline is Trouble with a capital T..I hate to think what would have happened had you not checked your bilge that day you noticed it took longer than usual to empty the bilge. Wouldn'ttake much to put that hole under water permanantly.
midnightsailor is offline
Basic Thoughts on Tides Jim Sexton Seamanship Articles 0 11-17-2003 07:00 PM
Devising a Better Bilge Pump Don Casey Gear and Maintenance Articles 0 06-02-2002 08:00 PM
Bilge Pumps:First and Last Lines of Defense Tom Wood Cruising Articles 0 05-20-1999 08:00 PM
