08-28-2009
Aluminum tank - normal chlorine in your water corroded the tank. You also probably found a lot of 'white sand' (aluminum chloridte) in the bottom. Aluminum makes LOUSEY water tanks because of the attack by chlorine.
Stainless steel tanks should have a minimum of welds, the welds ground smooth, .... then the tank should be passivated. Stainless 316 is the material of choice for water tanks. Polished stainless (internals) is best.
