Old 09-02-2009
SpcAlan1 is on a distinguished road
"Powered" Equipment on Sailboat
I have 2 marina batteries that run my lights and have a 110V ( ? ) cigarette plug in to run Iphone for music, spotlight, ect.
and I do have a Coleman trickle charge solar panel.
What other "electronics" do members have on their boat, that is run soley on their batteries ( not shore power ).
Someone said I could run a normal marine radio off the batteries?
What other "battery powered" electronics would work?
( I dont know anything about electricity currents ).
Old 09-02-2009
southshoreS24's Avatar
southshoreS24 is on a distinguished road
anything 12V would work, if it has a cigarette lighter adapter then it will work. Car and marine radio decks run off of 12v power. just be ware the more load you put on the batteries the quicker it will drain them and the longer it will take to charge them. with minimal loads a solar trickle charger is just fine, if your motor has an alternator or stator and charges the batteries when running, thats a good thing too.
Old 09-02-2009
I don't think my motor has an altenter or starter ( I may be wrong ).
it is a 9.9 Yamaha with a pull start.
I also saw a larger boat that had a windmill to provide power ( which is way too cool )
Old 09-03-2009
MacGyverRI's Avatar
MacGyverRI is on a distinguished road
I currently use 2 Deep cycle batteries @ 110 Amp Hrs. ea., 2 more will be added soon along w/ a Solar charger (Harbor Freight 45 watt for $219 w/ charge controller)
I use the 12 volt batteries for;
VHF 2 way marine radio
Running lights
Docking spotlight (rarely used)
GPS / Chartplotter
Depth finder
"Dual" Car type AM/FM/stereo/CD/MP3
Interior lights
12 volt Water Pump for water system/Shower/Faucets
Then, my 12 volt battery to 110 volt converter can also run;
Sharp 1/2 pint microwave (400 watts)
Small Mr Coffee maker
TV
Laptop Computer
Shore power (110 volt);
Battery charger
TV
Backup elec. ceramic heater (Propane is primary heat)
Point of use hot 110 volt water heater
My Outboard has an alternator so it also charges the batteries
HTH!
Ken, East Prov., R.I. Bootlegger, PY26 Paceship
If you like my posts, or they were helpful, please click the "scales" icon on top right to add Rep points.
Total Cost of owning a sailboat BoatKid5 General Discussion (sailing related) 38 10-07-2009 03:18 PM
Searchers continue looking for 3-year-old missing after sailboat ... - The State NewsReader News Feeds 0 06-09-2007 10:15 PM
