09-10-2009
the pointy end is the bow
The rubber bearing material should be in contact with the shaft all the way around (an interference fit). I've only replaced the cutlass bearing on boats with a bearing strut. In those circumstances, there is usually an allen head set screw that you loosen and they you use a bearing press to push it out or a sawz all to cut the bearing in half and pull it out. I'm not sure what holds the bearing in place when its in the hull.
Ray
S.V. Nikko
1983 Fraser 41
La Conner, WA
