-   -   Hull to Keel Repair (http://www.sailnet.com/forums/general-discussion-sailing-related/57949-hull-keel-repair.html)
weephee 09-12-2009 10:06 AM
Hull to Keel Repair
Can someone tell me what to use to seal the seam between the hull and the lead keel. Thanks
killarney_sailor 09-12-2009 10:19 AM
Crack at joint?
If it is the crack that develops between the f/g keel stub and an external keel, what worked for me was:
1. Clean up any loose material and let it dry comletely.
2. Fill gap with 5200 and let dry
3. Put a 3" piece of f/g tape over the the gap with epoxy resin (I used West epoxy and tape)
4. Fair and paint.
imagine2frolic 09-12-2009 10:44 AM
Are you sure you don't need to pull the keel? Do you have any pics? Is water weeping in? You wouldn't want to put a bandaid over some serious cancer.......i2f
weephee 09-12-2009 11:17 AM
Keel Repair
3 Attachment(s)
I have never had the boat in the water so I don't know if it leaks. I can see between the keel and the hull for about 6 inches back from the front point of attachment
imagine2frolic 09-12-2009 11:56 AM
Tha tlooks like a lot of seperation. Maybe you should pour water in the bilge, and see what appears outside? I would definately seperate the 2 no matter what. There is a great thread here on this exact subject from about 4 months back. One of the posters had great instructions with pics. If the yard wants to splash this boat with a bandaid on it. I would never return to the yard again.......i2f
Warren M. 09-13-2009 12:53 PM
In assessing how to repair the keel/stub joint, it is worth considering that a boat sitting on its keel on the hard, and a boat in the water (or hanging in slings), could present two entirely different situations. I would take a look at the keel/stub joint with the boat in the slings and then figure if a cosmetic or structural repair is needed.
