09-14-2009
Are you using a bridle because you have a catamaran? Perhaps the drill should be to rig the bridle first, then anchor. Once your anchor has set, move the chain rode over to the bridle plate (you should be able to walk it around the boat so the rode in the water goes to where you want it) and drop it into the slot on the plate, leaving your "lazy"loop on the side closer to the boat, so it stays hooked. This is just a guess since I've never anchored with a bridle, but it sounds like you've been trying to hook the chain to the bridle and then rig the bridle. It is easy to see how the chain could slip out of the bridle plate if you don't have it in a fixed position first. Hope this helps.
