09-17-2009
Catalina 27 through hulls
Through hull question:
I'm buying a 75 Catalina 27. The last thing to do was to haul it, power wash the hull and do an inspection. There's no "Catalina Smile", we only found one small (about half the size of a dime) blister, but the bottom paint is about gone.
My plan is bottom paint plus replace the through hulls. The previous owner had removed the head and holding tank which I'm fine with -- a porta-potti will be fine. I was going to have the yard replace the head intake and discharge through hulls and valves then plug them off.
The yard guy suggested I consider filling and glassing them over. It will be less expensive, I'll have two fewer holes in the hull, and he tells me that if, in the future, I or the next owner want to re-install a head it's no big deal to drill out the filled/glassed area and put it back to original. This sounds like a good way to go to me. Is there anything I', overlooking here?
